matthimself456 Posted November 22, 2022 Share Posted November 22, 2022 Sadly the end of the road has come for my 2005 Legacy GT wagon. It has rusted to the point where it is completely unsafe. Before I scrap the shell I want to pull the drivetrain. Possibly to sell or possibly to stash for a future FFR 818 project. I am semi-familiar with the normal method of pulling the engine out the top or dropping the transmission as one would do for a clutch replacement or engine rebuild but this time I need the simplest method to get everything out without having to plan for eventually putting it back together. The fewer bolts that have to come out the better (very rusty - lots of hardware is going to break or get stuck). Ideally if I could pull the engine, trans, turbo, downpipe, TMIC, everything as one unit that would be terrific. What doesn't come out is getting scrapped so I'm looking for the "junkyard hack" approach. Taking a sawzall or grinder to the core support, subframe, anything else is not out of the question. Can everything come out the top as one piece? Or if I hack up the core support and/or bumper can they come out the front? Would I be better off undoing the strut tophats and subframe and dropping everything out the bottom? Its a sad, unceremonious ending to a great car but the time has come... Link to comment Share on other sites More sharing options...
relative4 Posted November 22, 2022 Share Posted November 22, 2022 Once you've removed the radiator, condenser, bumper, etc., the engine and transmission can come out the front. Not sure if there will be overweight/balance problems using just the engine lifting eyes for the engine and transmission. A chain around the transmission might be good for extra support. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 22, 2022 Share Posted November 22, 2022 You may want to think before you go cutting the wires. You may need those for the ECU if you want to use this in the future. Make a list of what you think you want to cut. That way, you'll have a chance to do it right the first time. Thinking...if you have a lift, it might be easier to drop it out the bottom attached to the subframe... Hopefully, m sprank will see this, I'm sure he'll have good info. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
matthimself456 Posted November 22, 2022 Author Share Posted November 22, 2022 Good point. My goal is to not cut up any wiring. Especially because the entire engine harness was just replaced like 20k miles ago. Link to comment Share on other sites More sharing options...
subaru-tech Posted November 24, 2022 Share Posted November 24, 2022 Dropping the front subframe would be the easiest to get the engine and trans out at the same time Link to comment Share on other sites More sharing options...
