Whitesnake Posted November 19, 2022 Share Posted November 19, 2022 I would like to get an Impact driver set. Does anyone know the lug nut size the 2015 Subaru Legacy has so I can get a set that would include it? If anyone happens to know the size of a 2019 Subaru Ascent also? Thanks. Link to comment Share on other sites More sharing options...
ammcinnis Posted November 19, 2022 Share Posted November 19, 2022 The Gen 6 Legacy lug nuts are 19 mm (0.746 inch). I personally wouldn't use an impact driver on my Legacy's wheels ... except perhaps as a last resort when trying to break loose a seized lug nut. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
Whitesnake Posted November 20, 2022 Author Share Posted November 20, 2022 Thanks for the info.. I won't use it to tighten, just for take them off. BTW, what is the tork for tightening? Link to comment Share on other sites More sharing options...
ammcinnis Posted November 20, 2022 Share Posted November 20, 2022 4 hours ago, Whitesnake said: ... what is the tork for tightening? 88 ft-lbs. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
Max Capacity Posted November 22, 2022 Share Posted November 22, 2022 FWIW, for putting lug nuts on, I have a 3/8 butterfly impact gun, it only goes to 70ftlbs. I paid $19.00 for it over 15 years ago, it still works great. I also use it to remove the bolt that holds the blades on my mower deck. Makes getting the three blades a piece of cake. Also remember to use anti-seize compound on all threads, I torque lugs nuts to 80-82ftlbs with anti-seize. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
subaru-tech Posted December 16, 2022 Share Posted December 16, 2022 All subaru lugnuts are 19mm Link to comment Share on other sites More sharing options...
