chosimise Posted November 7, 2022 Share Posted November 7, 2022 Hi there! I am running into a problem with my 1996 JDM GTB wagon. The car was equipped with keyless entry system from factory, but the range is non-existence as I have to almost stick the key inside the window to get it to work 1 out of 5 times. I searched the forum and on the internet but was unable to get an answer for it. Is there an antenna unit separate from the control box? Anybody fixed a similar issue before? So far I have changed the battery in the key as well as unplugged, cleaned, re-plugged in the control unit but the problem persists. Thanks in advance! Link to comment Share on other sites More sharing options...
silverton Posted November 8, 2022 Share Posted November 8, 2022 The only keyless I messed around with was in my 1995 pathfinder, and that one did have a single wire antenna that had to be routed a certain way to avoid interference. I opted for an aftermarket alarm in my 2001 for better security and functionality. 1 Link to comment Share on other sites More sharing options...
doublechaz Posted November 8, 2022 Share Posted November 8, 2022 I'd say you'll have to get a copy of the factory service manual from around here and check the wiring diagrams for a single wire antenna and then verify its integrity and maybe try some routing. Only slightly related, I put an aftermarket head unit in my 300 and the WiFi single wire antenna for it has to be in there just right or I can't connect to the house from right in front of the house. 1 Link to comment Share on other sites More sharing options...
