Newguy304 Posted September 11, 2022 Share Posted September 11, 2022 Hi, new to Subarus but not bending wrenches. Daughter has a nice 06 Legacy (limited GT, auto, N/A, 148k) and it started overheating and missing. Pulled the engine and have pulled the heads off. Looks like the passenger side had a blown head gasket. Planning on taking the heads to be pressure tested, inspected and machined. What else should I do while to engine is pulled? I need to order the following parts but what brands are preferred or should I avoid? Recommendations on venders or sites? -head gaskets -gasket kits -CV half shafts -timing belt, water pump, thermostat -transmission fluid and filter -diff fluid -exhaust from y pipe back Not looking to make it a hot rod, just a dependable vehicle. Any info would be greatly appreciated. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 11, 2022 Share Posted September 11, 2022 All or most of those answers are on here, read some of the sticky's at the tops of the forums. Look in the DIY forum too. There is a sticky about "various parts" in the top of this forum with lots of info that most people forget about. Also OEM engine gasket set and ARP head studs. You can look at my "click here" link in my sig for some help. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
silverton Posted September 11, 2022 Share Posted September 11, 2022 13 hours ago, Newguy304 said: 06 Legacy (limited GT, auto, N/A, 148k -head gaskets -gasket kits -CV half shafts -timing belt, water pump, thermostat -transmission fluid and filter -diff fluid -exhaust from y pipe back a 2006 legacy gt but not a turbo? huh? head gaskets, OE or sixstar gasket kits, oe, mahle, victor reinz cv's, OE if available or trakmotive; if you get the HD trakmotives you need to replace both timing belt kit with water pump, OE or aisin, thermostat: OE, not a murray! fluids, dealers choice since you say it's not a race car...same for the exhaust. After replacing these head gaskets, change your oil every 3000 miles or you'll be doing head gaskets again. Link to comment Share on other sites More sharing options...
