Phosoup253 Posted August 26, 2022 Share Posted August 26, 2022 2005 legacy gt wagon Comfirmed that my bulbs were fine, don’t know why my reverse light would not work. I don’t see a fuse for it so what gives? Anybody have same issue, this a common problem? Solution to this? Link to comment Share on other sites More sharing options...
silverton Posted August 26, 2022 Share Posted August 26, 2022 Did you try new bulbs any way? If it's not the bulbs, it's likely the reverse switch on the transmission. Link to comment Share on other sites More sharing options...
Phosoup253 Posted August 26, 2022 Author Share Posted August 26, 2022 (edited) Yeah I swapped them to my side lights on the tail lights and bulbs seems to work just fine. Edited August 26, 2022 by Phosoup253 Link to comment Share on other sites More sharing options...
Max Capacity Posted August 27, 2022 Share Posted August 27, 2022 On a manual tranny, the switch is the forward one on the drivers side of the case. See the right side of the picture 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GearJamr Posted September 29, 2022 Share Posted September 29, 2022 My reverse lights weren't working when I bought my 05 wagon. Not sure how it passed safety but I digress.... I changed the switch and that worked for a little bit. Then I noticed my license plate lights didn't work. Then my high mount brake light. The wagons are notorious for the wiring cracking and breaking where it passes through the hinge area. Pull the rubber "guard" out and check the wiring. If any are broken, there are probably more, so look at all of them. If wires are broken, either replace the entire wire assembly or repair the wires. In short, check that all other tailgate functions are working. If not, head for the wires. 1 Link to comment Share on other sites More sharing options...
