prezton Posted August 12, 2022 Share Posted August 12, 2022 (edited) Car is running a OTS map from Matt Miner. Has a SPT cold air, GMS cat back, CNT high flow catted downpipe. That's it for tune mods. Hey all, have not posted on here in a while. Around a year and a half ago I bought a 09 LGT MT. Come to find out a month or two later the motor was no good, I was also getting consistent knock when going up hills? bad compression around most cyl with 4 being the worst (60 psi). Luckily I found a motor at my job where I went in blind with a leak down tester (didnt know what i was doing. ) But according to the directions the motor passed the leak down test. Fast forward today, I've put the "new" motor in. I did a cold compression test after driving it for about a week. All plugs out, with throttle down and the lowest cylinder being 113, the highest being 118. I still have been having this consistent issue that I was having with the last motor. My feedback knock will jump around when I am going up hills.. It happens A LOT in 3rd gear as well, at full throttle going uphill. Rarely does it happen when I am on a straight or down hill (sometimes it happens in higher RPMs third gear?). I do not see knock in 1st or 2nd gear at full throttle ever. Today my dam dropped to .75 and back up to .875 a few seconds later. The car has pulled great, it idles relatively well. Sounds like an average boxer. Haven't heard any audible knocks. I put group n motor mounts in, did almost all the gaskets on the motor. I genuinely do not know if the motor is junk and my warranty is going to end soon. (id assume my work would help me out but better safe than sorry.) I have been consistently trying to find the problem, with motor mounts. loose things under the hood, vacuum leaks, pcv. I have zip tied everything. I also feel like most of the 3rd gear knock happens around 80 mph. The car has an AWFUL power steering rack, and a god awful alignment. At above 75 the wheel will be shaking pretty rough. The rack I have not replaced as I don't want to invest much more till I know it is worth it. I'm going to leave some logs, but bare with me I have never put logs up before and don't know if I was supposed to shorten anything. Sorry for this being all over the place. -2.8 knock (the most consistent one ive seen, usually stays while im on the throttle going up hill.) https://docs.google.com/spreadsheets/d/16bs1JwTqoGBow7gGi0PNE0p_rv37CO_Fj1t0CR0YGl0/edit?usp=sharing 1-3 pull with slight knock in 3rd gear. https://docs.google.com/spreadsheets/d/1Ozy2kIIK8I8E-_zdG5xLI3-MTyDWyOiUBVEMrksqQz4/edit?usp=sharing -4.2 knock https://docs.google.com/spreadsheets/d/1y2_wA-eX3Y6vOvX6XkS5l3fD59BRnw44jwmsYd3DQY4/edit?usp=sharing -3.15 knock https://docs.google.com/spreadsheets/d/1TwQpneo1NiWdtqu5fl6eX8b6Tqzaeo5Krf16gfVpnKI/edit?usp=sharing no knock 3rd gear. likely on a straight https://docs.google.com/spreadsheets/d/17NPLghW9-dUFNZaCPtHcMnwVXzIDyyHZDP_BoVxyF_4/edit?usp=sharing log i noticed my dam was done(if i noticed i would not have gone into boost ;( ) https://docs.google.com/spreadsheets/d/1XdHWXwtEWi5wbowMsEa9UyLbRNYuBpFEjoSLjfkh_uY/edit?usp=sharing Edited August 12, 2022 by prezton link, correcting number Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2022 Share Posted August 13, 2022 Have you done a smoke test to see any vacuum leaks ? Is the MAF sensor clean ? spray it with MAF Cleaner. I'm not good with Log's, hopefully one of the experts will chime in soon. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
