Beamercub Posted August 9, 2022 Share Posted August 9, 2022 2015 3.6R Link to comment Share on other sites More sharing options...
ronemus Posted August 10, 2022 Share Posted August 10, 2022 The remaining range is calculated and cannot be totally relied on. There is a recall that updates the firmware to improve that feature. Has your car been done? Link to comment Share on other sites More sharing options...
ammcinnis Posted August 10, 2022 Share Posted August 10, 2022 3 hours ago, ronemus said: There is a recall that updates the firmware to improve that feature. That recall (WTW-82R) does not apply to MY 2015 Legacys or Outbacks. It only applies to some (not all) MY 2018 vehicles. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
XT-sub Posted August 10, 2022 Share Posted August 10, 2022 (edited) On 8/10/2022 at 4:26 AM, Beamercub said: 2015 3.6R In regards to the horns not working, it could be due to a faulty roll connector or horn switch. Check if you can hear the horn relay pulling in when the horn button is pressed. One way to test this is to hold the handle end of a long screwdriver against your ear with the other end resting on top of the horn relay, then get someone to press the horn button while the ignition is on. See attached diagram for the relay location. It would be unlikely that both 7.5A fuses would have blown, but worth checking (one 7.5A fuse No.1 for the RH horn & one 7.5A fuse No.2 for the LH horn). These are located directly below the horn relay (see attached diagram). 3 Fuse And Relay.pdf27 Horn System.pdf Edited August 11, 2022 by XT-sub Reason for edit: to correct fuse size. 1 Link to comment Share on other sites More sharing options...
ronemus Posted August 12, 2022 Share Posted August 12, 2022 On 8/10/2022 at 12:07 AM, ammcinnis said: That recall (WTW-82R) does not apply to MY 2015 Legacys or Outbacks. It only applies to some (not all) MY 2018 vehicles. I didn't realize the range of dates was so restricted - it did apply to my late-year production '17 2.5i. Link to comment Share on other sites More sharing options...
Beamercub Posted September 1, 2022 Author Share Posted September 1, 2022 Hey guys... The horn is just wonky.. Subaru thinks it could be the "clock spring" ? As for the gas range, I dunno what is going on. I have run out of gas a couple times because of it... I just don't let it go below half a tank at this point.. Link to comment Share on other sites More sharing options...
