lgb802 Posted August 6, 2022 Share Posted August 6, 2022 (edited) Howdy! This is my first post here but I have been reading the forum for years. Anyways - On the interstate the other day, when smoke/steam pours out from behind my vehicle. Pull over, see oil/grease all over the back-passenger side of the engine, under the turbo. Initially was sure I had lost my turbo oil return, but further inspection indicates that the rogue fluid is more viscous than engine or transmission oil, and is a thick grey. Now, I think that my CV boot let go and flung grease everywhere, but I still can't find where the grease would have come from. I have attached some photos of the area, in hopes that some of you may be able to confirm that the grease is from the CV. Any ideas on how the grease could escape while I still can't find a hole or fracture? Edited August 11, 2022 by lgb802 Link to comment Share on other sites More sharing options...
Tehnation Posted August 7, 2022 Share Posted August 7, 2022 Have you jacked the car up, put on some gloves and felt the entire boot with your hand? That definitely looks like grease from your cv boot. Axle has to come out regardless to repair, so might as well pull it and inspect it while its in your hand and pull it apart. The metal bands could have come loose, or might be a small slit or hole you can't see. 1 Link to comment Share on other sites More sharing options...
lgb802 Posted August 7, 2022 Author Share Posted August 7, 2022 Thanks for the reply! I felt around with gloves and didn't find any issues with the boot, but today I went ahead and pulled the axle out. Turns out, the joint completely failed, sprayed grease everywhere, and I still couldn't find the hole, haha. Oh well, just glad it's relatively inexpensive to fix. Is it possible to replace a CV joint, or do I have to replace the whole axle? Link to comment Share on other sites More sharing options...
Tehnation Posted August 7, 2022 Share Posted August 7, 2022 You either repair/rebuild the current axle or replace the entire axle, oem is a bit pricey I believe, but aftermarket sometimes has issues. Link to comment Share on other sites More sharing options...
Tehnation Posted August 7, 2022 Share Posted August 7, 2022 I think the automatics are much more picky about what axles you use! I have a manual and the cheap ones from rockauto worked fine for me. Link to comment Share on other sites More sharing options...
lgb802 Posted August 11, 2022 Author Share Posted August 11, 2022 Ended up rebuilding with a new boot, grease, and clips. Thanks for the help! 2 Link to comment Share on other sites More sharing options...
Tehnation Posted August 11, 2022 Share Posted August 11, 2022 Did you find the hole or was it one of the band clamps? Link to comment Share on other sites More sharing options...
lgb802 Posted August 11, 2022 Author Share Posted August 11, 2022 There was definitely a crack in one of the ribs of the boot. It ended up splitting into two sections as I pulled it out. 1 Link to comment Share on other sites More sharing options...
