Aeolus Posted August 3, 2022 Share Posted August 3, 2022 I've got old set of HSD coilovers that came on my old 2001 BE. The bushings in the rear passenger coilover is failing resulting in the rod that goes from what I think is the control arm to the bottom of the coilover bending. It looks like the disk between the bolt and the coiler failed and the nut is inside the bottom of the coilover. I didn't see what I thought I needed on HSD's website, but I don't have the vocabulary to know what I'm looking for beyond "bushing for coilover". I reached out to them so I'll see what they say. That said, my questions are: 1. Will I definitely need HSD bushings? 2. What name/terminology should I be using to look for the bushing and rod that goes through the. Bushing? 3. Has anyone replaced the bushing for their coilovers before and if so do you have any tips? I have found a few various ways on YT folks have used to remove the old coilover and replace it with a new one. Thanks! Link to comment Share on other sites More sharing options...
