AVCS cleaning/maintenance?
Just wondering if the AVCS needs a clean or not. I’ve got 270,000 miles original and wondering if it has to be done or not. Or if I should wait until the timing belt to do it? Looks like an involved project.
Only reason I ask is because I was looking to delete that union bolt filter. Then I went down a rabbit hole. Lol
thanks!
Other then when the heads were rebuilt. My 05 still has the OEM's installed.
Use good oil and you should be fine. I think you know these cars do better when driven for long distance. At lest long enough to get the oil hot and boil the moisture out.
  • Like 1
Engine Build - Click Here
You're talking about the avcs gears, right? I don't think they're supposed to be serviceable. People have definitely opened them and cleaned them, and there are write ups and videos. The problem is there's a flower shaped gasket that isn't sold. So if you break it (270k and 17 years old, btw) you're stuck buying used (gamble) or new.
  • Like 1
Uh, that's troublesome.. Because my job is literally less than 5 mins away. Ugh, other than parking it and getting a sh1tbox for these short trips, or getting a different job, any advice?
My job could be five min away, I take a long route to make it closer to 15 min so that I get properly warm on each trip.
  • Like 2
  • Thanks 1
