whitexc Posted June 2, 2022 Share Posted June 2, 2022 And there you have it. Thanks for that clarification white. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
boxkita Posted June 2, 2022 Share Posted June 2, 2022 ynansb is a tla couned by a long gone member (mrtris) for the impending trial of replacing your short block. when your engine oil burn rate approaches a diesel, you'll see "ynansb" in response. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
JJr Posted June 2, 2022 Share Posted June 2, 2022 (edited) I'll be listing my SWP 144k Wagon here soon and $10k would be a great deal, no YNANSB here! basically unmolested stg1 9 of 10 condition in and out too. Edited June 2, 2022 by JJr Link to comment Share on other sites More sharing options...
jams20 Posted June 3, 2022 Share Posted June 3, 2022 Thanks for the 101. Is there a general consensus on acceptable oil consumption per 1000 miles? (>1 qt you are in diesel territory) Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
JJr Posted June 3, 2022 Share Posted June 3, 2022 Sometimes a half QT here every 3.5-4k miles, maybe it's the 5EAT,lol Link to comment Share on other sites More sharing options...
Max Capacity Posted June 3, 2022 Share Posted June 3, 2022 Thanks for the 101. Is there a general consensus on acceptable oil consumption per 1000 miles? (>1 qt you are in diesel territory) Sent from my iPhone using Tapatalk Just think, using oil at that rate, your always's adding fresh oil, so you should be able to go longer between oil changes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jams20 Posted June 4, 2022 Share Posted June 4, 2022 Great point. Basically an oil change every 3k. 500 miles better than my current interval Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
jams20 Posted June 4, 2022 Share Posted June 4, 2022 <jk of course > Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Pleides Posted June 6, 2022 Share Posted June 6, 2022 If you're burning a noticable amount of oil on the dipstick within 1K miles your engine is probably not long for this world. My old engine burned a quart every 1K when I bought it with 202K on it and a quart every 500 miles when the engine came out at 214K. The car made a ton more power just having a new motor in it once everything was swapped, like 20 WHP per piston more. Link to comment Share on other sites More sharing options...
Infosecdad Posted June 6, 2022 Share Posted June 6, 2022 I’ve also seen engines go through approx 1 qt per 1k for 80k miles. It varies. Link to comment Share on other sites More sharing options...
Febreze Mee Posted June 7, 2022 Share Posted June 7, 2022 I’ve also seen engines go through approx 1 qt per 1k for 80k miles. It varies. Ooh, me! Me! Me! It's only been 40k miles though, but we're eating 1QT/500mi and have been under my ownership. Car has 155,504mi today. I bought at 118,000mi. Short block was replaced at 60,000mi. I've accepted the oil consumption for the time being. It's more expensive than I'd like it to be. Hoping the next short block doesn't consume as much. There aren't any external leaks. MILKRUN - Click Here Link to comment Share on other sites More sharing options...
relative4 Posted June 10, 2022 Share Posted June 10, 2022 just do stage 1 with UP. enjoy the car, you are on borrowed time. Yep, the rings are tired. Cold tests gave 95 PSI and 7% leakdown on all cylinders except #4 at 100 PSI and 4%. Apparently it doesn't know the rules. Sending a VF40 core off to JmP and will stick to stage 1 until I'm ready to rebuild. Link to comment Share on other sites More sharing options...
s2baru Posted June 10, 2022 Share Posted June 10, 2022 Could be bad oil lines too Fwiw Link to comment Share on other sites More sharing options...
jams20 Posted June 12, 2022 Share Posted June 12, 2022 Yep, the rings are tired. Cold tests gave 95 PSI and 7% leakdown on all cylinders except #4 at 100 PSI and 4%. Apparently it doesn't know the rules. Sending a VF40 core off to JmP and will stick to stage 1 until I'm ready to rebuild. Education for me. These results look positive no? Isn’t >20% where you have an issue or is the concern cylinder doing its own thing? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
relative4 Posted June 13, 2022 Share Posted June 13, 2022 Education for me. These results look positive no? Isn’t >20% where you have an issue or is the concern cylinder doing its own thing? The consistent results indicate the engine is not about to die, just midway along its long smooth ride to the finish. The sub-100 compression results indicate that the engine is not a good candidate for stage 2 boost levels. A really good engine should get 125 PSI, and Cryotune won't go stage 2 below 110 PSI. The low leakdown numbers are encouraging that the engine will last a good while longer if treated decently. Link to comment Share on other sites More sharing options...
Pleides Posted June 14, 2022 Share Posted June 14, 2022 The consistent results indicate the engine is not about to die, just midway along its long smooth ride to the finish. The sub-100 compression results indicate that the engine is not a good candidate for stage 2 boost levels. A really good engine should get 125 PSI, and Cryotune won't go stage 2 below 110 PSI. The low leakdown numbers are encouraging that the engine will last a good while longer if treated decently. Different gauges read differently, too. When I got my engine compression tested on the old block I saw 120 as my lowest and 140 as my highest. I'd bet your engine is in near-perfect health tbh. Link to comment Share on other sites More sharing options...
NORULZleggy Posted June 14, 2022 Share Posted June 14, 2022 These are not the only cars, I also have a 2013 2.5i and it love oil. Subaru did do a recall on it and agreed to pay for half of the short block to be replaced. I talked to my shop and they said just do your oil changes and keep and eye on it. It does burn oil and I add fresh oil every so often. this is the FB25 motor. with the cost of new cars, It will be cheaper to put a new short block in it and drive it. Link to comment Share on other sites More sharing options...
Haze Posted June 14, 2022 Share Posted June 14, 2022 Yep, the rings are tired. Cold tests gave 95 PSI and 7% leakdown on all cylinders except #4 at 100 PSI and 4%. Apparently it doesn't know the rules. Sending a VF40 core off to JmP and will stick to stage 1 until I'm ready to rebuild. The engine I pulled out of my '07 had 100 PSI on the two lowest cylinders and those had nasty vertical scoring on the walls. Not sure a 99.75mm re-bore would be enough to completely clean it up. At 95 PSI, I wouldn't count on this just being tired rings. Link to comment Share on other sites More sharing options...
relative4 Posted June 14, 2022 Share Posted June 14, 2022 Different gauges read differently, too. When I got my engine compression tested on the old block I saw 120 as my lowest and 140 as my highest. I'd bet your engine is in near-perfect health tbh. I used 2 compression testers, with consistent results. My first leakdown tester read 15% on 3 cylinders, then fell apart. The second tester gave me the 7%s. The engine does feel great, but unless somebody can recommend a compression tester I should use instead of my Harbor Freight toys, 95 PSI is what I got. Link to comment Share on other sites More sharing options...
whitexc Posted June 14, 2022 Share Posted June 14, 2022 You can likely rent a decent one from a local parts store or score one off Amazon.... Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
s2baru Posted June 14, 2022 Share Posted June 14, 2022 Not trying to be a negative Nancy here... Andddd just like that you have a ~4thousand dollar car instead. Link to comment Share on other sites More sharing options...
kzr750r1 Posted June 14, 2022 Share Posted June 14, 2022 The engine I pulled out of my '07 had 100 PSI on the two lowest cylinders and those had nasty vertical scoring on the walls. Not sure a 99.75mm re-bore would be enough to completely clean it up. At 95 PSI, I wouldn't count on this just being tired rings. 95 is about where cornpression tested on a full blown Ringland fail for #4. Already bored to 95.75 and now to 100mm. Funny and sad part is I never had an issue with oil consumption until changing to forged pistons. YMMV Link to comment Share on other sites More sharing options...
cleano5 Posted June 14, 2022 Share Posted June 14, 2022 In case anyone is following this, I have been trying to post a 2005 GT 5EAT with a brand new shortblock, heads redecked, valves done, turbo rebuild by Pure Turbos in Oceanside. Only mod is some lowering springs. Passes smog. I don't have priveleges to post in the classifieds and I have been trying for months. Link to comment Share on other sites More sharing options...
whitexc Posted June 15, 2022 Share Posted June 15, 2022 Gotta participate for privileges bud. It's not hard to get 15 posts or whatever it is. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
Infosecdad Posted June 15, 2022 Share Posted June 15, 2022 In case anyone is following this, I have been trying to post a 2005 GT 5EAT with a brand new shortblock, heads redecked, valves done, turbo rebuild by Pure Turbos in Oceanside. Only mod is some lowering springs. Passes smog. I don't have priveleges to post in the classifieds and I have been trying for months. https://legacygt.com/forums/showthread.php/our-sites-general-sale-rules-all-members-please-review-195213.html?t=195213 Link to comment Share on other sites More sharing options...
