2001wagonlegacy Posted April 7, 2022 Share Posted April 7, 2022 How’s it going everyone, I have a coolant leak can’t seem to find when I go to trouble shoot, but I see it’s coming from above oil pan gasket kit since there’s one dried up coolant streak on the right side of the oil pan from standing in front of car I was have one of those long stem cameras on order to help me see places I can’t see. I have a feeling it’s a gasket on the block somewhere, but Any recommendations anyone have once I dissect it with camera stem 2001 Subaru Legacy wagon Link to comment Share on other sites More sharing options...
silverton Posted April 7, 2022 Share Posted April 7, 2022 It's really hard to say what could be leaking with out seeing it. That side of the engine has the water pump, thermostat, and both heater core lines. Link to comment Share on other sites More sharing options...
2001wagonlegacy Posted April 9, 2022 Author Share Posted April 9, 2022 It's really hard to say what could be leaking with out seeing it. That side of the engine has the water pump, thermostat, and both heater core lines. Thank you, ima locate these areas, and further Trouble shoot Link to comment Share on other sites More sharing options...
Max Capacity Posted April 12, 2022 Share Posted April 12, 2022 Check the weep hole on the under side of the water pump. I had one leak there a few years back. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
2001wagonlegacy Posted April 15, 2022 Author Share Posted April 15, 2022 Thank you, I seen a dried up class two leak of coolant up near a corner of where two pieces seem to meet. Will try to post picture later once I figure out how to. Thank you Link to comment Share on other sites More sharing options...
