SuzyLegacy02 Posted March 19, 2022 Share Posted March 19, 2022 Hi. Im the second owner and have had this car for about 4 years. It has 99500 miles I have gone so far as to rebuild a ttansmission for a different car. So i need to know if draining and changing my ATF without changing the filter is ok or bad. Link to comment Share on other sites More sharing options...
silverton Posted March 19, 2022 Share Posted March 19, 2022 I have gone so far as to rebuild a ttansmission for a different car. So i need to know if draining and changing my ATF without changing the filter is ok or bad. what? if it has the external spin on filter, it's very easy to change, if it does not, just drain and refill. Link to comment Share on other sites More sharing options...
SuzyLegacy02 Posted March 19, 2022 Author Share Posted March 19, 2022 Thank you. I have looked for precision documetation to determine where the filter(s) are and cannot get a definitive answer for my exact car. I think i will just drain and add new fluidcwith some lucas. Thanks again Link to comment Share on other sites More sharing options...
SuzyLegacy02 Posted March 19, 2022 Author Share Posted March 19, 2022 Also im working in the street. So a thorough and slow process would be a problem for my neighbors Link to comment Share on other sites More sharing options...
silverton Posted March 20, 2022 Share Posted March 20, 2022 the spin on filter is easy like an engine oil filter. there is also an internal filter, but generally don't need to be replaced ever, unless you get rocks in there. Link to comment Share on other sites More sharing options...
AWDFTW Posted March 21, 2022 Share Posted March 21, 2022 OEM spin on external filter is like $20 bucks. That said, on my old 2003 it was rust seized on and more hassle than it was worth to deal with removing. Drain and fill is easy. Skip the Lucas. Not needed. Fresh Dex III will make that old 4 speed auto happy. Link to comment Share on other sites More sharing options...
