Harrimat Posted February 16, 2022 Share Posted February 16, 2022 I've been lurking the threads for about 3 years now, slowly maintaining my outback (2.5i shhh don't tell anyone), but never had anything to contribute. I recently went to the junkyard to look at the selection since my engine is going out but got distracted by a leather interior 2006 that must have been really cared for. an hour later I'm out of there with the seats, carpet, and some other various bric-a-brack. Some of you know where this is going. Long story short the 2005 system does not like 2006+ seats. I looked through the forum and only found methods for faking out the side airbags with resistors, or trying to use both the 2005 and the new seats hardware, or shoving the new upholstery over the old seat. It took a few days of thinking, but I came to the conclusion that all that is needed is to make a harness to interface the new seat's occupant sensor to the old connection, swap the SRS module in the dash for the correct year, and change out the seat belt for the 2006+ style. I made this quick little guide while looking busy at work today: 2005 Seat Swap 2006 2007 2008 2009 airbag fix.pdf Hopefully this makes the process easier for someone else in the future. If you have any questions let me know! 4 3 Link to comment Share on other sites More sharing options...
FrankensteinLegacy Posted January 4, 2023 Share Posted January 4, 2023 I did the same thing this summer, brought home some leather 06 Outback seats. I've been stuck trying to figure out the wiring on on the passenger side. I was also thinking about swapping out the main airbag module under the radio. Was it plug and play? Does that mean I need the whole harness from the airbag module to the seats? You don't have any airbag codes or any lights on the dash? Do you mind explaining a little more in detail on what you did to make it work? It would be much appreciated! Link to comment Share on other sites More sharing options...
Harrimat Posted January 4, 2023 Author Share Posted January 4, 2023 Hey! Trying to jog my memory on this You will definitely want to grab a 2006 or 2007 airbag module. These share the same pinouts as the 2005 module, but the logic on the occupancy sensor is different. By changing the ACM to the 06-07 vintage, you are able to not change out your harnesses. With the ACM swapped, the seat harness soldered up as shown, and the 2006+ seatbelt I haven't had any airbag lights and the system behaves as it should. I can try to answer more of your questions, I just need to get back in there and remember! Just let me know ow if I'm unclear in the pdf anywhere and I can try to fix it Matt Link to comment Share on other sites More sharing options...
FrankensteinLegacy Posted January 4, 2023 Share Posted January 4, 2023 Oh my bad! I first read your post on my phone late at night and didn't see you linked a "how-to" pdf! Wow you did an amazing job formatting and organizing! I've been going around in circles for months trying to figure out what to do! My LGT is already half apart so getting to the ACM is easy. I would avoid modifying any harnesses in my situation simply because before swapping seats, there were already airbag codes for communication errors involving the 2005 ODS etc. so I'm unsure if it was the ODS from the 05 or it could be a messed up harness between the seat and ACM or maybe even the ACM itself. My question is. Would it work to swap the ACM, seatbelt, and the entire harness to the front seats? I know it would be a lot more work since I would have to remove the carpet to replace everything but that ensures there would be no issues with the old harness. My guess it would work considering I'm swapping essentially everything at that point I was getting mixed answers on the ability to freely swap out ACMs. Some manufactures lock modules to the VIN but I'm happy Subaru didn't go that way. Link to comment Share on other sites More sharing options...
Harrimat Posted January 4, 2023 Author Share Posted January 4, 2023 (edited) No worries-- it sounds like you're almost there! Yeah, if you pulled a harness for your 2006 seats, they will route and connect to the 06/07 airbag module and you'll be golden. Those harnesses are IN THERE and tough to get out from my experience. That's when I decided to cut the connector off and just make sure the wiring went to the correct place. Have you found the service manuals for all the years you're working in? They really helped me out comparing the module connections to make sure I rewired as little as possible. I would bet your original problem may have just been a bad sensor in the seat. You could always check the +/- wiring on the ODS pins of the harness at the ACM and the seat for continuity to ensure that section is electrically OK. EDIT: nvm you are in a 2009 now so that old harnes doesn't really matter anymore-- whoops! Matt Edited January 4, 2023 by Harrimat reread your comment 1 Link to comment Share on other sites More sharing options...
FrankensteinLegacy Posted January 4, 2023 Share Posted January 4, 2023 I appreciate your help! I was close to throwing in the towel on this swap. A million times thank you! 1 Link to comment Share on other sites More sharing options...
Harrimat Posted January 5, 2023 Author Share Posted January 5, 2023 Of course! I'm glad it helped someone Link to comment Share on other sites More sharing options...
FrankensteinLegacy Posted January 6, 2023 Share Posted January 6, 2023 Alright. So I've decided that pulling out the entire harness is far too much work. You're right, they are really IN there. So I just got back from the scrap yard now with all my goodies. I will be building the harness shortly following your guide but I'm confused as to what this connector does? 2 pin connector with 1 wire only? What do I do with it? Male connector from the body harness on my LGT Female end from my original seat that I'll be taking the 4 pin from. Link to comment Share on other sites More sharing options...
seanyb505 Posted January 21, 2023 Share Posted January 21, 2023 Subbed for future shenanigans. 1 Link to comment Share on other sites More sharing options...
FrankensteinLegacy Posted April 7, 2023 Share Posted April 7, 2023 Wanted to post an update months ago but got side tracked. I followed the instructions and it works beautifully!! I'm so happy that damn airbag light is off on my cluster. Passenger occupancy works just as it would from the factory. Thank you so much for this amazing write up! Next up is fixing the CEL 3 Link to comment Share on other sites More sharing options...
Cory1750 Posted October 27, 2023 Share Posted October 27, 2023 Old topic but I am doing the same swap, 06 seats into my 05. The driver seat is plug and play but the passenger seat is different. The guide OP wrote is unavailable now @FrankensteinLegacy would you happen to have it downloaded anywhere? Or does @Harrimat still have it somewhere? Thanks. Link to comment Share on other sites More sharing options...
Harrimat Posted October 27, 2023 Author Share Posted October 27, 2023 14 minutes ago, Cory1750 said: Or does @Harrimat still have it somewhere? Thanks. Hello sir -- I think I have it on my home PC and can reup if necessary, but I did just click the link from my original post and the PDF seems to still be active. Link to comment Share on other sites More sharing options...
Cory1750 Posted October 27, 2023 Share Posted October 27, 2023 Oh it worked this time, weird. Was saying unavailable earlier. Maybe I had to be logged in, sorry lol I'm gonna look into this thanks for the guide! 1 Link to comment Share on other sites More sharing options...
FrankensteinLegacy Posted October 28, 2023 Share Posted October 28, 2023 2 hours ago, Cory1750 said: Oh it worked this time, weird. Was saying unavailable earlier. Maybe I had to be logged in, sorry lol I'm gonna look into this thanks for the guide! Good luck! It's much easier than it looks Link to comment Share on other sites More sharing options...
Harrimat Posted October 28, 2023 Author Share Posted October 28, 2023 3 hours ago, FrankensteinLegacy said: Good luck! It's much easier than it looks My bad for not getting back to your question back in January. Glad you got it figured out! Link to comment Share on other sites More sharing options...
ZachLush Posted April 8 Share Posted April 8 Hey there guys! This is my first time replying to a post! I'm doing a similar swap as everyone else here except I'm installing 05 seats in my 06 Legacy GT. I'm also filming the process and will be linking this topic on my YouTube channel! I have a full 05 parts car that I can steal parts from. Since I will be swapping the SRS module from an 05 into my 06 I'm guessing it might be okay to leave the 06 seatbelt in since the 05 SRS module won't even be looking for the tensioner sensor. Unless theres a difference in the seat mounting bolt, which I haven't tested yet. My 06 also never had an electric passenger seat, but I'm sure I can figure that out on my own! But my real question is what this white and purple wire are going too? I'm pretty sure white would be 12V going to the battery. Just really unsure about the purple. Also the harness I'm reffering too I removed from the 05 passenger front floor. Any help would be greatly appreciated! Link to comment Share on other sites More sharing options...
FrankensteinLegacy Posted April 8 Share Posted April 8 I'm unsure what the purpose of the purple wire is but I do know that I left that one alone. I just left it unplugged on the floor and it hasn't given me any issue! The white wire is the ods positive from what I can see. Link to comment Share on other sites More sharing options...
ZachLush Posted April 8 Share Posted April 8 1 hour ago, FrankensteinLegacy said: I'm unsure what the purpose of the purple wire is but I do know that I left that one alone. I just left it unplugged on the floor and it hasn't given me any issue! The white wire is the ods positive from what I can see. Thanks for the quick reply. Yes, that may have worked for you since you own an 05. However, I am installing 05 seats into my 06 so I believe I will need that purple wire due to having to run an 05 SRS module. Also the white wire is not ODS+ since I am using the end of the harness from the car, not from the seat. The wiring diagram provided in this write up does not work for me exactly since I'm using the opposite connectors and wires. I'm 99% sure its 12V to battery, which I am assuming I can just wire it up to any constant 12V source. I'm just really unsure about that purple wire. Link to comment Share on other sites More sharing options...
FrankensteinLegacy Posted April 8 Share Posted April 8 Ah right I see, I remember looking for the purple wire on the diagrams and could not find it at all. The last option if you really want to be sure is actually follow the purple wire to where it leads. It's a pain in the ass but at least you'll be sure. Link to comment Share on other sites More sharing options...
ZachLush Posted April 8 Share Posted April 8 1 hour ago, FrankensteinLegacy said: Ah right I see, I remember looking for the purple wire on the diagrams and could not find it at all. The last option if you really want to be sure is actually follow the purple wire to where it leads. It's a pain in the ass but at least you'll be sure. I may end up trying that later on. I'm currently trying to find where this connector is located and taping into it. Might attwmpt using the 05 seat and 06 SRS module since the purple and white wire are not being utilized. May work, may not... Link to comment Share on other sites More sharing options...
Harrimat Posted April 8 Author Share Posted April 8 (edited) That purple wire is part of the occupant detection system for the 2005, I believe it is a serial output for the Subaru Select Monitor. I would have to download the tech manual for the 2005 again to be sure. I believe it connects to the Airbag control module, but it might not have any direct use unless you're running a diagnostic. I'll have to try to refresh my brain on the system. It's been rock solid since I swapped everything and I don't ever have to think about it! I could be talking completely out of my ass. 2 hours ago, ZachLush said: I'm currently trying to find where this connector is located and taping into it. I believe I cut that connector out of the donor car just so I could keep the seat connector intact from the new seat in case I had to yank it out for some reason. **edit** the circled plug is the seat belt tensioner connection. Since the 2005 does not have this, I cut the harness out of the donor car just so that I could clip/unclip for install and wouldn't have to try to crimp with the seat in the car. This gives the 2006+ seat occupancy sensor information from the seatbelt Edited April 8 by Harrimat 1 Link to comment Share on other sites More sharing options...
ZachLush Posted April 8 Share Posted April 8 Thanks for the response! I'm going to try something a little bit different by using the 06 SRS module, 05 passenger seat, and I'll have to get that brown connector from a donor car. Might be awhile until that happens. If I make any discoveries I'll share it here! If you think I'm wasting my time and I shod just be using the 05 SRS module let me know. I know its been awhile since you wrote up this post! Link to comment Share on other sites More sharing options...
Harrimat Posted April 8 Author Share Posted April 8 (edited) Definitely feel free to give it a try. The worst case is it takes you a couple extra days and you'll still learn something in the process, I'm sure. I wouldn't say you'd be wasting your time--I think we all kind of enjoy the tinkering even if it leads to a dead end I'm just not confident that you can get the 2006 airbag control module to interface 2005 occupants detection system without running some sort of circuit in the middle to convert the output from the seat so the 2006 module can understand it. Do you have the service manuals for the two years? If not here are a couple pages that might help you with your tinkering. Here is a page from the 2005 manual on the airbag system: The 2006+ start giving the occupant system it's own page: Edited April 8 by Harrimat Added wiring diagrams Link to comment Share on other sites More sharing options...
ZachLush Posted April 9 Share Posted April 9 Thanks for sharing! I will post if I make any break throughs. 2 Link to comment Share on other sites More sharing options...
ZachLush Posted April 16 Share Posted April 16 Hey! I got it working and wired up lastnight! You were correct Harrimat, I had to use the 05 airbag module. After doing that I followed your wiring diagram and gave the white wire a 12V constant power source and the occupation detection works flawlessly. (I used the 12V power from the seats). The purple wire and 3 blue wires are currently not being used and it seems to work just fine. Also the marettes were being used for testing, after I tucked the wires they were removed and joined properly. To give the passenger seat power I made a T-harness from my donor car that plugs into the driver seat and runs to the passenger. I ended up cleaning everything up after but it looks very OEM now! I also had to swap the passenger seatbelt for the 05 since the mounting point is smaller and the 06 is too bulky to mount to the seat. I'll be posting a YouTube video about it later on and I'll share the link on here when I do! But I now have 05 seats working in my 06 LGT. Thanks! 3 Link to comment Share on other sites More sharing options...
