Front left wheel hub for BH5 GTB
I'm looking for the part number for the front left wheel bearing and hub assembly for the BH5 gtb. Which other subarus use the same part and does anyone know the part number? I need to make sure I get the right part.
Best regards
The BH should have the same partnumber as the BE, youll have to comfirm fitment on the following are the part numbers and location for each of the parts i used on the front wheel bearings for my USDM BE. Not sure on the hub assembly as I reused my OEM hub flange.
Timken front wheel bearings both sides (p/n 517008 )
Timken front wheel bearing retainer C clips both sides (p/n RET176 )
SKF front inner and outer wheel seals both sides (p/n 22026 & 22032 )
Beck/Arnley replacement spindle nuts for the front (p/n 103-0504 )
