pik1111 Posted January 29, 2022 Share Posted January 29, 2022 (edited) SOLD Time has come to let go of the track wagon. I am moving out of state soon and won't be close to any tracks. This car has been a years long project for me some of which I have detailed in other threads here. This car is a conversation starter at the track for sure. Some history... I bought the car new in 2005. Virtually every system on the car has been upgraded. I have put a lot into this car, over $40K in parts alone. Here is the run down: 2005 Legacy GT Limited Wagon OBP 5MT 1995 Featherlight 3110 aluminum open top trailer ~110K miles The motor and tune were done in 2018 by Drive Autosports from an IAG Stage III Tuff closed deck block with a Blouch Dominator 1.5 XT-R it dyno'd on a Dynapack @ 332WHP/352WTQ. This setup can make more power but my goal was around 330WHP as I wanted good power and reliability. The interior has been completed gutted and 425 Motorsports installed a roll cage. I have used this exclusively for track days but it does have valid WA plates. I don't do use this car for drag racing, and I don't do hard launches. In fact don't even have the rev limiting launch control or flat foot shifting enabled in the tune. So I could not tell you what it's 0-60 time is or what it will do in a 1/4 mile. But I can tell you it is a blast to drive fast around a road course. I have changed the oil with fresh Motul v300 after every track day. I just had the Motul 660 brake fluid changed and system bled. The front rotors and pads have 1 track day on them. NOTE: The front coilovers need replaced. These can be ordered from BC Racing individually. The are about $300 per corner. Here is the shopping list for the build: Engine bay •IAG Stage III Tuff Closed Deck block w/ 1/2" head stud kit and cooper ring head gaskets5475 •Blouch Dom 1.5 XT-R 8CM 3in inlet coated1800 •Refresh Cylinder heads (valve grind, valve stem seals, surface and guide repair1491 •11 mm oil pump200 •Process West TMIC w/ custom Boxkita shroud 1100 •Crawford v2 AOS356 •Killer-B Oil Pan, Pickup, Windage tray550 •Killer-B Holy 4 into 1 header coated1800 •Perrin Oil cooler782 •Koyorad radiator330 •Gimmick Racing Turbo Inlet280 •WRX flywheel200 •South Bend Clutch Stage 3 Endurance 1138 •Fluiddampr crank pulley450 •Zerolift TGV delete200 •Phenolic spacers 60 •Cobb 1050cc top feed injectors653 •Aluminati fuel rails250 •Grimmspeed catless uppipe for EWG350 •Tial 38mm EWG300 •Grimmspeed brake master cylinder brace100 •Optima RedTop battery250 •SPT exhaust (custom with resonator and SPT mufflers and muffler deletes)1000 •Turbosmart BPV 166 •Invidia catless downpipe350 •Higher pressure radiator and expansion tank caps (Crawford and STI) 100 •DeatschWerks (9-652-1008) 265 LPH Compact Fuel Pump 150 •Intercooler sprayer (repurposed rear washer line to intercooler) •AC delete •Heater delete Interior •Ecliptech ShiftP2 shift light190 •Prosport Oil pressure and temp gauges in center cubby250 •6 point roll cage (425 Motorsports)6000 •Sparco Evo II drivers seat800 •Recoro Pole Position N.G. passenger seat800 •Sparco 6 point harness (shoulder harness: 3 inch on drivers, 2 inch on passenger)800 •Sparco Fire suppression system400 •Suede DashMat cover (for glare and to cover white sticky dash)60 •Battery shutoff switch (not a kill switch, battery saver)60 •Sparco 015L750SC Wheel Diameter 350mm L575 Steering290 •Recaro Seat sliders400 •Planted seat brackets380 •NRG steering wheel disconnect112 •SPT short sifter and bushing 200 •Momo shift knob200 •Custom Fire extinguisher mount •Custom front door panels w/ Sparco pulls •USB Power outlet •Custom carbon fiber center console with fire pull, Fan and Tune switch •Suspension / Brakes •2016 STI steering rack with Whiteline steering rack bushings500 •2004 STI Brembo brakes conversion with speed bleeders1000 •DBA T3 ClubSpec 4000 Slotted rotors (new fronts)660 •BC Racing DR SeriesvDigressive PistonvCoilovers LGT with Swift 10K springs1510 •"Saggy butt" spacers on rear 100 •Spec B alumimun bits400 •AVO rear anti-roll bar brace120 •Cusco roll bar (23 mm front and 21 mm rear)400 •Cusco steering rack brace60 •Whiteline end links200 •Whiteline KTA124 Rear Control Arm assembly342 •Whiteline bushings •Agency Power sway bar end links240 •Stainless steel brake lines150 •EBC Yellowstuff pads 300 Exterior •Custom Carbon fiber Sunroof insert (Northwind Composites)425 https://northwindcomposites.com/2017/02/03%e2%80%b2-09%e2%80%b2-subaru-legacy-bp-sunroof-delete-officially-for-sale/ •Madrig carbon fiber hood scoop250 •CTI Rear diffuser 300 •Rolled fenders •Front and Rear tow hooks •Grillcraft grill insert350 •JDM style front lip100 •Primitive Racing skid plate320 •HID headlight upgrade and LED Brake and turn signal lights •Wheels / Tires •Enkei PF01 Wheels (17x8", 45mm, 5x100) with Toyo RR 235/40ZR171228 •TSW Nurburgring 18x8 Bronze with Bridgestone Blizak LM-32 225/40R18 1000 Fluids •Motul 660 Racing Brake fluid •Motul 5w30 300v Racing Oil (changed after every track day) •Water and Redline water wetter coolant •Motul Gear 300 75W90 in rear diff •Transmission cocktail of Redline Lightweight Shockproof and Motul Gear 300 Tune •Drive Auto Sports tuned on dynapack dyno (332 HP / 352 TQ)506 •Total of parts: $41,284 Like I said I am moving and am a motivated seller I am making a screaming deal . Asking price for wagon and trailer together: $12,500 or best offer Additional pics: https://www.icloud.com/photos/#0a6arKM-CA-lOoeny2hTlt_oA Lap vid Edited February 14, 2022 by pik1111 Link to comment Share on other sites More sharing options...
pik1111 Posted January 29, 2022 Author Share Posted January 29, 2022 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
shralp Posted January 30, 2022 Share Posted January 30, 2022 Bump for a good guy with a sick track car! I know you mentioned thinking about selling when I saw you last fall, hate to see it go! Link to comment Share on other sites More sharing options...
tehspud Posted January 31, 2022 Share Posted January 31, 2022 This seems like an insane deal for the right person. I kinda wish I was that person. Link to comment Share on other sites More sharing options...
whitexc Posted January 31, 2022 Share Posted January 31, 2022 Especially with the trailer. That is worth some coin on its own. GLWS. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
Ratmilk Posted January 31, 2022 Share Posted January 31, 2022 Bump, kind honest seller. Wish I had the space for this, the price is a steal. Link to comment Share on other sites More sharing options...
Enlight Posted February 2, 2022 Share Posted February 2, 2022 I keep coming back to this page to see if it has been sold yet. This would be at least a one week trip for me, but my tow vehicle is also needed for plow service back east. muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
pik1111 Posted February 3, 2022 Author Share Posted February 3, 2022 Bumped Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
s2baru Posted February 8, 2022 Share Posted February 8, 2022 Holy smokes, deal here!! Link to comment Share on other sites More sharing options...
pik1111 Posted February 8, 2022 Author Share Posted February 8, 2022 Holy smokes, deal here!! I know right? You should buy it [emoji3] Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
s2baru Posted February 10, 2022 Share Posted February 10, 2022 I told John he'd be a better owner than myself. Link to comment Share on other sites More sharing options...
Febreze Mee Posted February 10, 2022 Share Posted February 10, 2022 But John's already endlessly getting rid of stuff himself MILKRUN - Click Here Link to comment Share on other sites More sharing options...
Gex Posted February 13, 2022 Share Posted February 13, 2022 Sold to meeeeee! Link to comment Share on other sites More sharing options...
Enlight Posted February 13, 2022 Share Posted February 13, 2022 Congrats! Glad this is staying on the forum. muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
sez752 Posted February 16, 2022 Share Posted February 16, 2022 Great buy, surprised it took this long. Have fun in it. Can't lie, little jealous haha. Link to comment Share on other sites More sharing options...
whitexc Posted February 16, 2022 Share Posted February 16, 2022 Trailer too? Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
