wintergreen Posted December 18, 2021 Share Posted December 18, 2021 I understand the my 2005 LGT has B25 heads on it and in later years they came with D25 heads that had higher compression ratios. Will a short block from a 2007 WRX to replace my 2005 LGT block work? I will be putting the B25 heads on it. The block should be identical, I'm not sure about the piston dish or dome if there is a difference that would affect compression ratio. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 18, 2021 Share Posted December 18, 2021 There isn't enough difference to worry about. My 05 GT wagon has a ej257 from 2012, just buy the engine gasket set for your year car. When we did the street tune at 500 miles, the Tuner said there wasn't enough difference in the tune between the two blocks to make any difference, but he did a little clean up on the fueling or something, that was over 146,000 miles ago. Read my click here link. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
silverton Posted December 18, 2021 Share Posted December 18, 2021 https://www.flatironstuning.com/blog/what-is-the-difference-between-an-ej255-and-an-ej257 Link to comment Share on other sites More sharing options...
Max Capacity Posted December 18, 2021 Share Posted December 18, 2021 (edited) Thanks, I now remember seeing that in the past. As I read that, I see the OP will be fine using his B25 heads on his 2007 short block Seems having B25 heads makes it possible. From the Flatironstuning link. "Because of the difference in piston dish and combustion chamber volume, it is not recommended to pair a D25 head with an STI block, or one that was designed to work with B25 heads." So the 07-09 GT's and OBXT's should select the ej255 shortblock. Edited December 19, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
