Bad Ringlands? What is this stuff in my engine?
Hello,
I bought a used engine awhile back and I am just now starting to tear into it, haven't taken the heads off yet but I put a boroscope into the spark plug holes to take a look. 2/4 cylinders look good with the cross hatching still visible, however, the other 2 have what looks like caked oil or something. I wouldn't be surprised it the ringlands are bad because it's got around 140k on it. The engine has also not been run in almost a year. I just wanted to confirm what I'm seeing is oil or something and not bits of the shortblock.lmk of you guys notice anything else.
Thank you4d5c0cdc9e3b9bc71bc66f60661ba5ea.jpg285c58763a2dc4b150c3bc3577ab38e4.jpg6a97e71cbd36cccf28cf8e2865bc522c.jpgb51f1592010a6a7ca7beced830e23bef.jpg
Sent from my SM-G970U using Tapatalk
I'm not sure how you could discern that from a lip on the ring, and just oil sitting there in the gap; that picture isn't clear enough.
Gotta keep in mind the turbo is on the 1/3 side so that head gets a lot more heat and is more susceptible to carbon build up.
Right, what I was hinting at earlier, was the need for a better picture.
Here are mine at 154,000 miles.
Edited by Max Capacity
Engine Build - Click Here
[ATTACH]294197[/ATTACH]
[ATTACH]294198[/ATTACH]
I was planning on getting it honed and just doing some drop in pistons if the block looks usable. I'm fairly certain the ringlands aren't ideal due to the age of the engine. Assuming there is no major scoring and the cylinders aren't severely out of round would it be safe to assume my plan would be viable?
My Machine Shop owner buddy, told me, I was better off buying a new ej257 shortblock, instead of paying him to tear apart my ej255 and rebuild it. Others have learned the same thing.
Most dealers can get an ej257 and engine gasket set for your year car for about $2300.
My ej257 has over 144,000 trouble free miles on it.
Yeah, I would for sure go the new shortblock route, however, I think it would be fun to go through the rebuilding process on my own. There's a ton of resources online and worse case I mess it up really bad I'll just move to another project.
I got a shortblock rebuilt for basically a total of $1800. that was the machine work, which it needed to be bored out, and assembly (both of which were about 1200 total) with new rod and main bearings (acl race) and pistons and rings from subaru. (about 500-600).
zero tangible benefit from replacing a 255 with a 257 unless you're doing the rest of it too. crank, rods, and pistons are the same in the 255 and 257. the 257 "benefits" are in the size of the heads combustion chamber, fuel injectors, larger turbo, and more aggressive tuning on the ecm.
We all go with the ej257 because back when we started doing that, the 257 was cheaper than the ej255.
Supposedly the ej257 had the better crankshaft. That was the main benefit.
  • 2 weeks later...
Are there any notable differences between the D25 heads, and the B25 heads in terms of capability that come with the 257/255 respectively?
  • 2 weeks later...
Small update, took a look at the heads. They are pretty dirty but couldve worse I guess. I didn't see any obvious scoring but I'll be moving it this week closer to my house so I can get into taking the heads off. Still got to get those cam bolts off. Another big reason why I'm going the route of rebuild this engine is because I got it basically for free :)6c809ca3c265a3fd63fecf8272262045.jpge0c08a8e4d0c7fc70ad7a661f48bfd73.jpg
From my understanding, the B25 heads were used in the 05-08 STI then they went to the W25 heads with dual ACVS. Meanwhile the D25 heads were used to compensate for air injection due to emissions.
