DanTinIdaho Posted October 18, 2021 Share Posted October 18, 2021 (edited) I couldn't find all the proper information on how to do this so I figured I could contribute and hopefully help someone else do this in the future. I have a 2002 Outback with the double/split headlights. I purchased the 2004 headlights with the 9007 headlight bulbs. Obviously they aren't the same and thus the harnesses have to be swapped and rewired. Before and After. Top is old, bottom is new. https://www.dropbox.com/s/usqvjaglh6yq71p/Photo%20Oct%2017%2C%207%2056%2050%20PM.jpg?dl=0 I first ordered the harnesses from Amazon ACDelco Professional LS256 Headlamp Socket: https://www.amazon.com/dp/B001DRN63C/ref=cm_sw_r_cp_api_glt_fabc_VQN7K92GT8MBSWPPTABX?_encoding=UTF8&psc=1 https://www.dropbox.com/s/s6pxbncv6vicztp/Photo%20Oct%2017%2C%208%2048%2025%20PM.jpg?dl=0 Next, the wiring setup. From the car harness, the wiring is as follows: Yellow wire: Low beam Blue wire: Ground/negative Red wire: High beam With the harness facing you female end, and in a upwards rainbow shape, the following is how the wires must be connected and I've attached a picture. https://www.dropbox.com/s/0ndkt8ns8fqifxs/Photo%20Oct%2017%2C%208%2055%2027%20PM.jpg?dl=0 Left: High beam Middle Up: Ground/Negative Right: Low Beam I hope this helps everyone. Cheers. Edited October 18, 2021 by DanTinIdaho Link to comment Share on other sites More sharing options...
Soobyhobby Posted October 18, 2021 Share Posted October 18, 2021 (edited) So it sounds like you put Legacy headlights on an Outback. 2000-2004 Legacy GT and 2000-2004 Outback have split headlights. Share the same assemblies. 2000-2004 regular Legacy has single bulb (dual element) headlights. Edited October 18, 2021 by Soobyhobby Link to comment Share on other sites More sharing options...
geotop Posted Thursday at 03:32 AM Share Posted Thursday at 03:32 AM Khoan Địa Chất please 1 view. thanks veryone Link to comment Share on other sites More sharing options...
