Enock Muhangi Murungi Posted October 14, 2021 Share Posted October 14, 2021 am not very technical; but i have some great responsibility towards my car. i listen to any unusual sounds and run for check ups at the slightest warning of something gone wrong. well my issue is my gear shifter is hard!!! yah the mechanic has tried to adjust it ,somewhere under the pedal, clutch plate is fine; pressure, release bearing are all good. It happens a lot in the morning; gears one and two are hard; i have to clutch in a couple of times for it to engage;...if anyone has had this issue and has solved it - will be glad to learn from you. NB; car is 100% stock, JDM, 200K+ mileage, daily drive Link to comment Share on other sites More sharing options...
Max Capacity Posted October 15, 2021 Share Posted October 15, 2021 Have you had the fluid changed ? I have found that Motul Gear 300 is the best stuff for these tranny's. 105777 is what you want. https://www.google.com/search?q=motul+gear+300&rlz=1C1OKWM_enUS906US906&sxsrf=AOaemvJU4VIDaZo6f9V9Yx3_JCWtUv8p2g:1634301309775&source=lnms&tbm=shop&sa=X&ved=2ahUKEwjehpnotszzAhUCZjUKHTBmBiQQ_AUoAXoECAEQAw&biw=1280&bih=881&dpr=1#spd=15031498912439925711 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
norutah Posted October 16, 2021 Share Posted October 16, 2021 (edited) Have you checked your shifter bushings? How much side-to-side play is there in the shifter? Fresh bushings, especially firmer bushings, and a readjustment of shift linkage made a lot of difference in my car. Sent from my HD1925 using Tapatalk Edited October 18, 2021 by norutah Link to comment Share on other sites More sharing options...
Enock Muhangi Murungi Posted October 17, 2021 Author Share Posted October 17, 2021 let me check these too, Link to comment Share on other sites More sharing options...
Max Capacity Posted October 18, 2021 Share Posted October 18, 2021 Not many people talk about these cars being hard to shift. If yours only shifts hard in the morning, maybe someone put the wrong (thicker) fluid in it. 75w-90 is what these take, not 75w-140. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JMack Posted October 18, 2021 Share Posted October 18, 2021 Lol... I hate to look at this. My car does this, but it is not temperature dependent. I am just biding my time (and my pocket / marriage) until I want to spend a bit of money to fix this. I am guessing I will do this and the clutch at the same time (165,000 miles). Link to comment Share on other sites More sharing options...
