98 2.5 Legacy transmission swap AT to MT
Hi, guys.
Time for wire harness has come. Got into troubles setting up ECM to MT.
Which pin shold I jump/ground in? Which connectors is related to neutral position and back lights?
* My TCM is within the ECM, not a separated part.
Someone to help?
Edited by LMBelo
All my reference material is for 95 which is a weird transition year between OBDI and OBDII so it won't match what you have. The Factory Service Manual has what you are looking for and is out there for download.
Hi. I've found a similar manual. On this gen ECU, when the automatic transmission connectors are disconnected, the ECU automatically sets to manual. So far, it only requires the neutral jump.
