Max Capacity Posted October 5, 2021 Share Posted October 5, 2021 (edited) Knock on wood... I may have gotten away with a simple fix for this. Over the past few thousand miles, I would get a CEL with this code. I replaced the gas cap again, as I did a few years back. Remember I'm retired now so I don't rack up the miles like I used to. About a month ago I saw a video showing how to make sure the valve is not leaking. You can blow into the ports and suck on them. If you can't blow or suck air, the solenoid valve is good. (the light blue connector) I took mine off a couple of weeks ago and could not blow or suck through it. When I put it back on, I zip tied the three hose ends. Edited February 4 by Max Capacity 304,000miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Rusty9 Posted October 5, 2021 Share Posted October 5, 2021 looking forward to more of your suck and blow tales Link to comment Share on other sites More sharing options...
Max Capacity Posted October 5, 2021 Author Share Posted October 5, 2021 Hey, if it that test is correct, the issue was the lack of zip ties on the 17y/o hoses. 304,000miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Rusty9 Posted October 5, 2021 Share Posted October 5, 2021 I don't doubt it. When I had my car tuned 8 years ago the guy was anal about putting a zip tie on EVERY vacuum line connection. Link to comment Share on other sites More sharing options...
Pleides Posted October 5, 2021 Share Posted October 5, 2021 Zipties and vacuum caps on these cars break too y'all, never forget to check them every so often. You'd be amazed at what trivial things can break and how they can affect a turbo car! I still couldn't believe I had a boost leak out the passenger side cam position sensor. That little o-ring turned into a brick and that was the end of it. Car had trouble starting, poor MPG, whole works. Link to comment Share on other sites More sharing options...
SubOperator Posted October 6, 2021 Share Posted October 6, 2021 Thanks Max. I am getting P0442 quite often, may try sucking and blowing since that valve is all original... and no zip ties. Otoh, the rear passenger side stinks gas here and there, which sucks on itself. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 244K 2007 B9 Tribeca Limited DGM - 243K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
apexi Posted October 12, 2021 Share Posted October 12, 2021 Thanks Max. I am getting P0442 quite often, may try sucking and blowing since that valve is all original... and no zip ties. Otoh, the rear passenger side stinks gas here and there, which sucks on itself. Wonder about your fuel filler neck. Noticed mine was pretty rusty in some spots earlier this year. Hit it with a bunch of fluid film to hopefully stop it from spreading. It doesn't look like it'd be super hard to replace when I was fiddling with the wheel well liner removed and stuff, but looks could be deceiving. In the thread below they said it's a pita Pic max posted in the past https://legacygt.com/forums/showpost.php?p=5837785&postcount=7 Link to comment Share on other sites More sharing options...
SubOperator Posted October 13, 2021 Share Posted October 13, 2021 I might drop the liner to assess the condition of the filler neck and related lines. The CEL says "small leak" and the smell is not coming too often, so I am hoping the neck itself is OK. If it comes to that I as well look at the tank and rear brake lines - dropping subframe is not something I want to do at some point again. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 244K 2007 B9 Tribeca Limited DGM - 243K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
Max Capacity Posted October 15, 2021 Author Share Posted October 15, 2021 Oh well, the codes came back. P0442 and P0457. It's been over 600 miles. When I walked near the gas cap, I could smell a little gas. I reset the CEL, zeroed the "trip meter". I drive it for a while and wait until my garage is finished before I decide to pull the rear wheels and fender liners and see what things look like. 304,000miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
apexi Posted October 15, 2021 Share Posted October 15, 2021 (edited) Going off memory, I thought maybe you could inspect the problem areas on the fuel filler pipe without removing the fender liner, so I checked today out of curiosity. In max's picture that I posted above , you can see the really rusty area without removing anything, but to inspect the rest, you really do have to pull back the fender liner (I know that may be obvious). I took a bunch of pictures in case they might help someone in the future. The first time I did this I removed the fender liner, which was a little annoying with the little air flap that sits in front of the wheel. This time around I removed most of the fasteners, and just pulled it back and held it back with a bungee cord, not touching the little air damn thing that sits in front of the wheel. In the last picture, the two red circles are fasteners that are kind of hidden, especially the one on the right. The first picture is what you can see without pulling back the fender liner, fuel filler neck circled in blue Edited October 16, 2021 by apexi Link to comment Share on other sites More sharing options...
SubOperator Posted October 16, 2021 Share Posted October 16, 2021 Thanks for the pics, very helpful. I think this is where the root cause of cell P0442 I am getting is - I did look at the engine and recalled that everything I could buy was refreshed about 3 years ago when I pulled the engine and tranny for 6 speed swap. Including all the small houses and such around intake. Apexi did you find here the leak is actually coming from? Just curious if it can be patched somehow for the time being. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 244K 2007 B9 Tribeca Limited DGM - 243K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
apexi Posted October 16, 2021 Share Posted October 16, 2021 (edited) My filler pipe didn't have any leaks so I'm not sure if they can be patched. I can't remember why I removed both rear fender liners during the summer. I think I was fluid filming parts of my car, and I removed them for better access. Edited October 16, 2021 by apexi Link to comment Share on other sites More sharing options...
NoOne1223 Posted October 17, 2021 Share Posted October 17, 2021 Gonna see how much it will add to my tank replacement to get a new filler neck.. Would help prevent a future major issue Link to comment Share on other sites More sharing options...
Max Capacity Posted October 17, 2021 Author Share Posted October 17, 2021 My filler neck was replaced when my tank was back in 2017. Just saying. 304,000miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SubOperator Posted October 18, 2021 Share Posted October 18, 2021 Gonna see how much it will add to my tank replacement to get a new filler neck.. Would help prevent a future major issue Makes sense to replace filler neck if the tank is being replaced, imho... 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 244K 2007 B9 Tribeca Limited DGM - 243K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
SubOperator Posted October 18, 2021 Share Posted October 18, 2021 So today - 90 miles up north to Ayer Mass, full day of autocrossing, then 90 miles down south to home - and not a single peep from damn CEL. Gas smell is there. Did I say before that cars are like women? 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 244K 2007 B9 Tribeca Limited DGM - 243K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
madrig Posted October 18, 2021 Share Posted October 18, 2021 i did the neck when i changed the tank , just to be done ! Link to comment Share on other sites More sharing options...
apexi Posted October 18, 2021 Share Posted October 18, 2021 Cracked pump housing? https://www.subaruoutback.org/threads/gas-odor-does-my-filler-neck-look-ok-pics.496271/post-5810443 Link to comment Share on other sites More sharing options...
SubOperator Posted October 19, 2021 Share Posted October 19, 2021 Cracked pump housing? https://www.subaruoutback.org/threads/gas-odor-does-my-filler-neck-look-ok-pics.496271/post-5810443 Interesting. Much easier to check the pump housing than drop the gas tank. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 244K 2007 B9 Tribeca Limited DGM - 243K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
Holla Posted October 20, 2021 Share Posted October 20, 2021 Have you had the car smoke tested yet? These small leaks can really be a bear to track down. Link to comment Share on other sites More sharing options...
SubOperator Posted October 21, 2021 Share Posted October 21, 2021 Have you had the car smoke tested yet? These small leaks can really be a bear to track down. I have not. Some other things need to be taken care of, so it comes to priorities. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 244K 2007 B9 Tribeca Limited DGM - 243K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
Max Capacity Posted October 28, 2021 Author Share Posted October 28, 2021 (edited) Well today the CEL came back on P0442. When I went to put gas in the tank, I could not fill the tank at normal fill rate. The nozzle kept clicking off. I'll have to check out that issue. I know there are threads here about it. The engine started fine after I put 5 gallons in. I reset the cel, car started fine. Here's one thread I found, https://www.subaruoutback.org/threads/gas-pump-kicks-off-when-filling.39645/page-3 Edited October 29, 2021 by Max Capacity 304,000miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted October 28, 2021 Author Share Posted October 28, 2021 FYI, just checking prices. Purge valves. https://shop.advanceautoparts.com/web/SearchResults?searchTerm=+pruge+valve&filterValue=isFitted_uFilter%3AExact+Fit&storeId=10151&catalogId=10051&langId=-1 304,000miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted October 28, 2021 Author Share Posted October 28, 2021 More info. https://grassrootsmotorsports.com/forum/grm/gas-tank-wont-fill/38528/page1/ 304,000miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SubOperator Posted October 28, 2021 Share Posted October 28, 2021 Well today the CEL came back on P0442. When I went to put gas in the tank, I could not fill the tank at normal fill rate. The nozzle kept clicking off. I'll have to check out that issue. I know there are threads here about it. The engine started fine after I put 5 gallons in. I reset the cel, car started fine again. Here's one thread I found, https://www.subaruoutback.org/threads/gas-pump-kicks-off-when-filling.39645/page-3 Interesting. I do not believe my wagon has that problem, yet it throws P0442. Just walked past it in garage, faint smell of gasoline and the car wasn't driven for 2 days. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 244K 2007 B9 Tribeca Limited DGM - 243K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
