AC Blows hot then gets cold after I turn off/on
Hello,
I have a 2009 legacy GT (no turbo) and recently the A/C will sometimes start blowing hot air. I found that if I press the A/C button to turn it off, then hit the A/C button again, it will blow cold air for a while. This doesn't appear to work if I turn the power to the heating/cooling off, only if I use the A/C button.
Any idea what this could be?
Not sure if it makes a difference but for most/all of this summer the A/C barely blows cold air when idle but gets cold once I give it some gas.
Thank you,
Brian
Have you noticed that all four face-pointed climate vents blow warm air, or just the ones by your face? All three blend door actuators on my car are bad with 16 years on them. I sometimes get warm air on my face from the center one that tends to be cured for a minute if I drastically drop the temperature or turn it off for several minutes and turn it on again.
You could also need an A/C recharge.
Great point^ and I'll add it could be a failing AC Relay. MY 08 GT would do this, last year, checked the relay with a multi meter and it was junk. plugged in a new one and problem solved.
The blend door issue is a bit more involved to fix, getting to and greasing the mechanism, but I too need to do that at some point.
Yep, the AC relay is $7.00 part and is in the under hood fuse box. I replaced it years ago when my wagon would blow cold for 30 minutes or so then go hot. I'd shut off the AC for a few minutes, then turn it on again, it was fine.
A little while later, I had the system serviced by a Pro.
Engine Build - Click Here
Thank you. I'll replace the relay and see if that works. For $7 it's worth a try!
Sorry for the delayed response, had to wait for the AC to do it again. All vents are blowing warm air.
