Kaliman198117 Posted July 21, 2021 Share Posted July 21, 2021 So I replace the following on my 2010 Legacy 2.5 1.Lower control arms straight from Subaru, it comes with lower ball joints 2.Away bar links 3. Sway bar rubber bushings 4. Front and rear struts (KYB) 5. Strut mounts Before the install my car was ride terrible but the biggest issue i was having was a rattling metallic noise every time I went over rough terrain, you could really hear it, very annoying, reason why I decided to replace all parts i mentioned above. Now, the car rides better definitely, however, i can still hear that noise, not as loud as before but i know is there. What can possibly be the issue here? Can it be motor mounts or what. The router tide rods were replaced about a year ago i doubt is that. I really need help finding this problem i can't sleep. When I press on the gas pedal you can also hear a metallic rattling noise, I'm not sure if they are related . Any help will be greatly appreciated guys i know there is a lot of knowledge here. Thanks a lot for reading. Gman Sent from my LE2115 using Tapatalk Link to comment Share on other sites More sharing options...
coco26 Posted July 21, 2021 Share Posted July 21, 2021 I had a rattling issue that I thought was suspension for a while. Turns out it was the rubber sleeves on the brake caliper slide pins. The calipers were essentially rattling around on the pins. I'd make sure those are still providing some cushion. Link to comment Share on other sites More sharing options...
Plastixx Posted July 21, 2021 Share Posted July 21, 2021 (edited) When I press on the gas pedal you can also hear a metallic rattling noise, I'm not sure if they are related. Exhaust heat shields. If your Subaru doesn't eventually get this problem, then it's not a Subaru. To fix mine I bought a custom length hose clamp kit off amazon that comes with enough pieces to make 10 custom length clamps. I went crazy and clamped the **** out of the shields. I think I put 8 or 9 of them on. Edited July 22, 2021 by Plastixx Link to comment Share on other sites More sharing options...
Alexmed2002 Posted July 22, 2021 Share Posted July 22, 2021 Exhaust heat shields. If you're Subaru doesn't eventually get this problem, then it's not a Subaru. Had this happen on my 2013 Legacy a week before I sold it a year ago . Link to comment Share on other sites More sharing options...
Kaliman198117 Posted July 23, 2021 Author Share Posted July 23, 2021 I will check all this issues you guys made comments about, they all make sense to check. Sent from my LE2115 using Tapatalk Link to comment Share on other sites More sharing options...
Kaliman198117 Posted July 23, 2021 Author Share Posted July 23, 2021 Exhaust heat shields. If your Subaru doesn't eventually get this problem, then it's not a Subaru. To fix mine I bought a custom length hose clamp kit off amazon that comes with enough pieces to make 10 custom length clamps. I went crazy and clamped the **** out of the shields. I think I put 8 or 9 of them on.Do you have a link to that custom hose Sent from my LE2115 using Tapatalk Link to comment Share on other sites More sharing options...
Plastixx Posted July 23, 2021 Share Posted July 23, 2021 The listing for the kit I bought is gone, but there are countless others to choose from. Like this one... https://www.amazon.com/LINGSFIRE-Stainless-Fasteners-Adjustable-Automotive/dp/B096ZT9DWK/ That kit has 8mm wide strap like the one I bought. Most listings are for 12mm/0.5" wide strap, which I had bought at first but then returned. I found 12mm a bit too wide and stiff to work with for this purpose. Link to comment Share on other sites More sharing options...
