Matthew352 Posted July 19, 2021 Share Posted July 19, 2021 95 Subaru Legacy L Abs(disc brakes) Ok so I had a rear brake line break. So I replaced both rear lines then when bleeding everything noticed the PF,DR (pass front, driver Rear)calipers not compressing, nor could I get but a drizzle out of bleeder. So I replaced the calipers , yet I'm still have no compression or brake pressure. Is there something else that could be causing this? Abs need bled? Any suggestions are appreciated... Link to comment Share on other sites More sharing options...
doublechaz Posted July 20, 2021 Share Posted July 20, 2021 Sounds like the ABS is full of air. I don't have it so never learned it, but the FSM should give a procedure for how to bleed the ABS. You can download it around here somewhere. Link to comment Share on other sites More sharing options...
