CT05Legacy Posted June 28, 2021 Share Posted June 28, 2021 I haven’t found anything from searching. The LH fuel injector pipe is starting to rot and leak fuel. Can this be replaced without removing the intake manifold? Item 13 in the image. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
rhino6303 Posted June 29, 2021 Share Posted June 29, 2021 Technically you could do it without removing the manifold but it would be awful. You'd save time removing the manifold. Also, if that part is so corroded, it's probably time to change intake manifold gaskets and maybe fuel lines as well. Link to comment Share on other sites More sharing options...
CT05Legacy Posted September 27, 2021 Author Share Posted September 27, 2021 Thanks. Some of the other fuel pipes under the manifold look a little rough too. Good thinking. Do I really need to drain coolant to pull the manifold? Do I need to follow each step in the FSM of removing the intake to remove get to the fuel rail? Seems coolant needs to drain because of the lines that go to the throttle body. But any way to keep most things intact just to get to the fuel rail? Link to comment Share on other sites More sharing options...
