SpaceKassel Posted June 13, 2021 Share Posted June 13, 2021 Waiting to get my car in the shop for the lovely P0011 code/rough idle & trying to figure out the best way to approach everything. Started a post in the turbo forums with the link below if anyone has any info or ideas. Much Love & Thanks https://r.tapatalk.com/shareLink/topic?url=https%3A%2F%2Flegacygt%2Ecom%2Fforums%2Fshowthread%2Ephp%3Ft%3D286222&share_tid=286222&share_fid=5383&share_type=t&link_source=app Sent from my Pixel 3 XL using Tapatalk Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 14, 2021 Share Posted June 14, 2021 If you flush the engine and the oil cooler there is no way to tell how long it will run and when it may die. Best game plan if you want to keep the car is a new short block and have your heads cleaned up. The bolts caught the junk but you need to find out where the junk is coming from. Did your turbo have a lot of shaft play? Oil pan have lots of debris? while i dont have any engine trouble I am well into the 200k miles club and i too think about should I rebuild or not when the time comes Link to comment Share on other sites More sharing options...
SpaceKassel Posted June 14, 2021 Author Share Posted June 14, 2021 If you flush the engine and the oil cooler there is no way to tell how long it will run and when it may die. Best game plan if you want to keep the car is a new short block and have your heads cleaned up. The bolts caught the junk but you need to find out where the junk is coming from. Did your turbo have a lot of shaft play? Oil pan have lots of debris? while i dont have any engine trouble I am well into the 200k miles club and i too think about should I rebuild or not when the time comes That's what I'm fearing. Haven't gotten it to my mechanic yet, hopefully in the next few days. Planning on pulling/checking the -2 banjo bolt screens -turbo -oil pan Also replacing the intake gaskets and searching for a light oil & exhaust leak Sent from my Pixel 3 XL using Tapatalk Link to comment Share on other sites More sharing options...
SpaceKassel Posted June 23, 2021 Author Share Posted June 23, 2021 So thankfully upon pulling the oil pan it was clean of metal shavings and the engine looks good! The turbo on the other had has play in both blades and will need to be replaced. Has anyone tried the Turbos from Rock Auto? Looking at the Ultra-Power or Rotomaster but haven't found any reviews on either yet. Wish I could upgrade but just trying to get back on the road at this pace. Sent from my Pixel 3 XL using Tapatalk Link to comment Share on other sites More sharing options...
ttnio Posted June 23, 2021 Share Posted June 23, 2021 check the oil pick up tube unit... Link to comment Share on other sites More sharing options...
bdcvg Posted June 23, 2021 Share Posted June 23, 2021 Don't get anything but a OEM turbo or a JMP rebuild or the can of worms will be open. Link to comment Share on other sites More sharing options...
SpaceKassel Posted June 24, 2021 Author Share Posted June 24, 2021 Don't get anything but a OEM turbo or a JMP rebuild or the can of worms will be open.Thank you bdcvg Do you know of any trusted suppliers for an OEM or whatever is most cost efficient? Sent from my Pixel 3 XL using Tapatalk Link to comment Share on other sites More sharing options...
bdcvg Posted June 24, 2021 Share Posted June 24, 2021 You just have to dig a little, amazon , e-bay and direct from Subie dealers all have close but varying prices. Link to comment Share on other sites More sharing options...
awfulwaffle Posted June 24, 2021 Share Posted June 24, 2021 (edited) I had Mahle turbos recommended to me by a local Subaru master tech, the ones available on RockAuto. So far, I have 2 customers running them without issue, older one for about a year. Seems like a reasonable cheaper alternative to OEM. Their VF52 is like 600 bucks and the quality looks top notch. EDIT: Scratch that, looks like prices have gone up. Still, 700-800 bucks. If you need a working, used VF46 to replace the stock turbo on your car, I have one around somewhere. Edited June 24, 2021 by awfulwaffle Link to comment Share on other sites More sharing options...
SpaceKassel Posted June 24, 2021 Author Share Posted June 24, 2021 I had Mahle turbos recommended to me by a local Subaru master tech, the ones available on RockAuto. So far, I have 2 customers running them without issue, older one for about a year. Seems like a reasonable cheaper alternative to OEM. Their VF52 is like 600 bucks and the quality looks top notch. EDIT: Scratch that, looks like prices have gone up. Still, 700-800 bucks. If you need a working, used VF46 to replace the stock turbo on your car, I have one around somewhere.Thank you for the feedback awfulwaffle! This car has been adding up repair bills quickly. I would greatly appreciate a proper used turbo over buying new. I'll dm you shortly Sent from my Pixel 3 XL using Tapatalk Link to comment Share on other sites More sharing options...
