3.6rxbbie Posted June 8, 2021 Share Posted June 8, 2021 I have a ‘15 3.6r and I have the nameless axleback muffler delete coming soon and i was thinking about getting a 3” midpipe made and put in? Not too knowledgeable about this stuff so was looking for guidance/thoughts about this. Thanks Link to comment Share on other sites More sharing options...
boxkita Posted June 8, 2021 Share Posted June 8, 2021 that delete is going to be loud. adding a 3" mid isn't going to reduce the noise volume either Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Max Capacity Posted June 8, 2021 Share Posted June 8, 2021 (edited) Check out post #13 here, https://www.subaruoutback.org/threads/no-emissions-no-inspection-not-ridiculously-loud-exhaust-suggestions.533143/#post-6118910 Those mufflers may work better with a 3" mid pipe. Other than noise, I doubt there's any performance gain...? I think there are other threads in the 2015-2019 Outback forum about exhaust too. Here's one, https://www.subaruoutback.org/threads/nameless-5-axle-back-exhaust-installed.533327/#post-6114210 Edited June 8, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
3.6rxbbie Posted June 8, 2021 Author Share Posted June 8, 2021 Those mufflers may work better with a 3" mid pipe. Other than noise, I doubt there's any performance gain...? Yeah i’m not really looking for performance gain out of it, more so sound/making the delete sound a little better. I Will check it out, thank you. that delete is going to be loud. adding a 3" mid isn't going to reduce the noise volume either Looking more so to make the delete sound a little better than noise control Link to comment Share on other sites More sharing options...
