NoOne1223 Posted June 5, 2021 Share Posted June 5, 2021 So, not sure if this is the right place to put this, but, knowing the issues that the stock oil feed for the turbo gives, would it be a good idea to put a "T" connector on an oil pressure sensor and take oil from there, and put in an inline filter for the turbo? Thanks in advance! Link to comment Share on other sites More sharing options...
Max Capacity Posted June 6, 2021 Share Posted June 6, 2021 Your over thinking this. I'm still using the stock oil feed setup at 297,000 miles. Just make sure you remove both banjo filters. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
