tucka Posted June 1, 2021 Share Posted June 1, 2021 Can someone please explain how to adjust the rear camber on a 96 wagon awd model. Link to comment Share on other sites More sharing options...
Brighton96 Posted June 1, 2021 Share Posted June 1, 2021 The lateral arms that bolt the bottom of the hub to the center diff subframe thing. If you crawl under the car, look above the diff to where the lateral arms bolt into the subframe, you'll see a little plate that has markings on it, those are the bolts that adjust it. Link to comment Share on other sites More sharing options...
doublechaz Posted June 2, 2021 Share Posted June 2, 2021 And if fully original there were big black plastic dome covers with teeth around the edges covering those bolts. Link to comment Share on other sites More sharing options...
tucka Posted June 2, 2021 Author Share Posted June 2, 2021 cheers for the help got it all sorted! Link to comment Share on other sites More sharing options...
