kwatson9316 Posted April 18, 2021 Share Posted April 18, 2021 I need help in locating a part number for item 15 in the attachment. It says it is a camshaft support. Just in case the picture doesnt help it is located on the front of the drivers side head and houses the cam position sensor on the EJ22 engine. I messed up and it wasnt all the way seated when I tightened the bolts so it cracked. Thanks for any assistance. Link to comment Share on other sites More sharing options...
doublechaz Posted April 18, 2021 Share Posted April 18, 2021 Pretty sure salvage yard is your only answer. I would research if that item is line bored to the cam journals. If it is you would probably be better off getting a whole head from salvage. Link to comment Share on other sites More sharing options...
kwatson9316 Posted April 18, 2021 Author Share Posted April 18, 2021 Pretty sure salvage yard is your only answer. I would research if that item is line bored to the cam journals. If it is you would probably be better off getting a whole head from salvage. I hadnt thought of that, UGH! I did a lot of work to those heads. Link to comment Share on other sites More sharing options...
Brighton96 Posted April 19, 2021 Share Posted April 19, 2021 I have one I was going to send off to the junkyard with my donor car. You can have it if you want it. Link to comment Share on other sites More sharing options...
kwatson9316 Posted April 20, 2021 Author Share Posted April 20, 2021 I have one I was going to send off to the junkyard with my donor car. You can have it if you want it. That would be awesome!! I sent you a PM Link to comment Share on other sites More sharing options...
