Northern1 Posted April 12, 2021 Share Posted April 12, 2021 I thought I'd be able to pull out the MAF sensor and clean it by removing the 4 small phillips screws that holds it in the housing however the sensor does not come out, there is resistance. Is there something else internally holding the sensor unit? My other option is just to pull out the whole housing around the MAF sensor. Just wondering if the sensor does come out after removing the screws or not. Thanks! Link to comment Share on other sites More sharing options...
Brighton96 Posted April 12, 2021 Share Posted April 12, 2021 I'm pretty sure you have to just uncouple it from the air filter box. I don't recall it being removable from the section of tube it's mounted on. Link to comment Share on other sites More sharing options...
Northern1 Posted April 12, 2021 Author Share Posted April 12, 2021 OK, thanks. I thought it would just come out with the four screws loose. Link to comment Share on other sites More sharing options...
rdleg05 Posted April 16, 2021 Share Posted April 16, 2021 Its built into the tube that exits the air cleaner housing and connects to the intake. You should be able to loosen the large band clamp from the MAF tube to intake and then open the air cleaner box (like you are changing air filter) and lift up the backing of the air cleaner container which has the tube with the MAF in it. cheers rdleg05 Link to comment Share on other sites More sharing options...
