Shogun506 Posted April 3, 2021 Share Posted April 3, 2021 All of the threads on here with people talking about swapping to an EJ257 are met with a "too expensive/ need too much stuff" etc type answer. Here is a different take on the question. I just found a totalled 2011 STI at an auction near me that sustained a rear end collision. The engine and trans are untouched. The car can actually still drive. The reserve price is really low and I put in a bid. If I happen to win this thing I intend to essentially absorb everything possible from this entire car into my LGT. With that said, I will have access to everything and this could easily turn into both an epic build or more than I can chew. I need input from people with more experience in this field. Main concerns: -Can this entire long block with all of its accessories work on my 05? From what I gather I'll need to swap my ECU to the STI one to make the dual AVCS work. If I'm swapping the ECU I guess I'm going to run into immobilizer issues unless I swap that system too? I guess I'd even have to sell my accessport and buy a SUB-003 vs my current SUB-002. -Does the 6 speed need to go in at the same time as the 257 or can I do them one at a time? Mainly asking this because I need to do more research on the 6 speed swap to make sure all the stuff is compatible. -Is there some combination of EJ257 longblock parts I could scavenge onto my EJ255 that would allow me to get the most benefit while reselling the remainder at the highest price? I would ideally love to just bolt the new engine in whole and sell the old one whole but if I have to mix and match I don't want to waste anything. Also before anyone asks, the only reason I'm even considering this is because essentially at my current bid it'd be like buying a 257 long block and getting a free STI everything (6 speed trans, brembos, suspension parts, wheels, STI seats and interior among other things) that I can sell or transplant. My current motor is fine and my car drives great but the kms are always ticking up and I was planning on moving on to power gains soon anyway. I wouldn't mind having a backup powertrain sitting in my garage, but only if it's actually capable of functioning properly in my car. Input appreciated. Link to comment Share on other sites More sharing options...
boxkita Posted April 3, 2021 Share Posted April 3, 2021 steering rack moves over - lookup undrrdog's thread engine moves over. romraider has a parch to make dual avcs work on a 4th gen. idk about cobb, guessing it would work. transmission is pretty much a bolt up provided you have the right driveshaft the front spindles/wheel bearings/wheels can be used. The rear suspension probably doesn't work (i tried an 08 sti, nothing matched without lots of custom work) The front seats can be loved over. There's a thread on it. Something about a resistor being added. Steering wheel should work. the rest, not much left? if you get it, make a thread. Don't give up. It would be a cool swap. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Shogun506 Posted April 9, 2021 Author Share Posted April 9, 2021 I got it $4000cad. Thread to come Link to comment Share on other sites More sharing options...
Max Capacity Posted April 9, 2021 Share Posted April 9, 2021 This should be interesting. Looking forward to it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
