awfulwaffle Posted March 23, 2021 Share Posted March 23, 2021 With the motor going back together shortly, bigger turbo because bad decisions, been thinking about FMIC kits versus a GS TMIC. ETS and AVO seem to be the only 'premium' FMIC offerings, other than making my own kit and buying a separate core. Looking at the size of the ETS core, and the pictures from ETS, looks to me like about half of it is blocked by a non-modified 05-07 bumper. Curious what, if anything, those of you who run this kit might have done to improve flow routing and how it ended up looking. Thanks! Link to comment Share on other sites More sharing options...
socalsleeper Posted March 23, 2021 Share Posted March 23, 2021 I'm just here to see peoples responses. Link to comment Share on other sites More sharing options...
boxkita Posted March 23, 2021 Share Posted March 23, 2021 I was in the process of returning the race wagon back to a top mount (found a complete processwest to put in); so have the Perrin fmic. The Perrin was tucked in behind the oem bumper and used ductwork on the front. you might want to do some aero modeling on the fmic before deciding on purchase/mounting. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
awfulwaffle Posted March 23, 2021 Author Share Posted March 23, 2021 you might want to do some aero modeling on the fmic before deciding on purchase/mounting. Ever the motivator you are. That's a good idea - maybe there's a way to promote flow higher up onto a blocked intercooler, though I have my doubts based on how tight the axial spacing is. Just need to jam some CFD time between working the day job, running a shop on the side and going to school part time. Might have to give up my weekly beer hour Link to comment Share on other sites More sharing options...
boxkita Posted March 23, 2021 Share Posted March 23, 2021 Something about high-speed air through a radiator being bad hence needing room for the air to slow down. So a narrow opening that expands to fit the radiator then contracts to create draw/suction? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
BrandonspecB Posted March 23, 2021 Share Posted March 23, 2021 I have the ETS core and built my own tubing. I didn't do anything as far as ducting. I cut the front bumper as close to the intercooler as I could. Don't have much as far as airflow stuff, but I do have temp data. First pic is a third gear pull, 16 psi. Inlet temp is the air going into the turbo. EGT 7 is air coming out of the turbo. Intake air temp is air going into the throttle body. It manages to pull all the heat out. Second pic is 1st through 4th gear, 16 psi. I didn't have the other sensors installed so I only have one temp sensor. Only had about a 30 degree increase throughout the pull. I've really likes this intercooler. ETS makes quality stuff. Link to comment Share on other sites More sharing options...
boxkita Posted March 24, 2021 Share Posted March 24, 2021 is that an outback hood? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
awfulwaffle Posted March 24, 2021 Author Share Posted March 24, 2021 I have the ETS core and built my own tubing. I didn't do anything as far as ducting. I cut the front bumper as close to the intercooler as I could. Don't have much as far as airflow stuff, but I do have temp data. First pic is a third gear pull, 16 psi. Inlet temp is the air going into the turbo. EGT 7 is air coming out of the turbo. Intake air temp is air going into the throttle body. It manages to pull all the heat out. Second pic is 1st through 4th gear, 16 psi. I didn't have the other sensors installed so I only have one temp sensor. Only had about a 30 degree increase throughout the pull. I've really likes this intercooler. ETS makes quality stuff. Great data, thank you for sharing. I'm curious how a thinner core that still fills the window in the bumper would stack up. I'd expect some additional pressure loss if heat transfer efficiency was the same, but maybe it'd be minimal... Link to comment Share on other sites More sharing options...
BrandonspecB Posted March 24, 2021 Share Posted March 24, 2021 is that an outback hood? It is. Great data, thank you for sharing. I'm curious how a thinner core that still fills the window in the bumper would stack up. I'd expect some additional pressure loss if heat transfer efficiency was the same, but maybe it'd be minimal... What turbo and how much power do you want? 300 hp worth of air probably not that big of difference. 600 hp you'd probably notice it. This is assuming same quality of core just different thickness. Link to comment Share on other sites More sharing options...
m sprank Posted March 26, 2021 Share Posted March 26, 2021 ETS makes the best core/kit for Subies. ETS cores on all the big builds. Bigger the turbo, thicker the core. [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
