noobieofdeath Posted December 12, 2020 Share Posted December 12, 2020 (edited) First off, sorry if I’m not doing this right. 96 Legacy Brighton 2.2 5 speed... CEL turned on otw to work, 65 mph. Was 28°ish, light snow. No change in performance. If no light, I would have never suspected a thing.. I got to work and pulled a P0500. Kinda read up on it, but drove home after work suspecting maybe tire slippage on snow(?). Everything was normal. Speedometer works, does 65+, will rev very high when punched (no tach in Brighton), really nothing different... Disconnected battery to clear code. Started this morning with CEL still. Same P0500. Pulled cluster and tightened the screws behind speedometer, checked sensor at gearbox- found and repaired nick in wire. Disconnected battery. Started up and CEL and (only) P0500 still showing. Drove around a bit to see if it would turn off. Drives normal, idles normal, speedometer reads right, revs high (I’m assuming redlining but no tach) when punched, just the light stays on. Voltmetered battery, 14.7ish at idle. Wtf? Any ideas? Edited December 12, 2020 by noobieofdeath Link to comment Share on other sites More sharing options...
doublechaz Posted December 13, 2020 Share Posted December 13, 2020 The CEL comes on right when you start it before the car moves? That would seem to indicate an open or short circuit to the sensor or an electronically blown sensor so that the computer can sense a problem without movement. You would really need a Factory Service Manual for your year to systematically check the wiring. The steps would be checking continuity on some wires and check for voltage or ground on some. An OBD II tool that can view live data would help a lot, too. For this kind of thing I use an elm327 OBD II to Blutooth adapter and the Torque Android app. Should be under $10, but there are other similar options for iphone etc. If you look around this site for my Vacation Pictures you should be able to see some of the relevant diagrams in some of the shots. Some of the links are dead so you might have to try a few. Link to comment Share on other sites More sharing options...
noobieofdeath Posted December 13, 2020 Author Share Posted December 13, 2020 doublechaz Thanks for your reply. That is exactly what is happening. I was hoping for a “you forgot to [insert incredibly easy oversight here], dummy” answer. Lol. Diagnosing electrical and wiring is way above my threshold of pain for a 96 legacy. I’ll have to drive her into the ground. RIP The Snot Rocket. (Maybe she’ll still roll a few years like previous soobies too stubborn to die.) Fortunately I have her replacement, El Pato Verde, a 96 outback standing by and ready to rumble. Thanks again and happy holidays! Link to comment Share on other sites More sharing options...
ehsnils Posted December 13, 2020 Share Posted December 13, 2020 doublechaz Thanks for your reply. That is exactly what is happening. I was hoping for a “you forgot to [insert incredibly easy oversight here], dummy” answer. Lol. Diagnosing electrical and wiring is way above my threshold of pain for a 96 legacy. I’ll have to drive her into the ground. RIP The Snot Rocket. (Maybe she’ll still roll a few years like previous soobies too stubborn to die.) Fortunately I have her replacement, El Pato Verde, a 96 outback standing by and ready to rumble. Thanks again and happy holidays! Depending on where in the world you are there might be someone around to give you a hand with it. Link to comment Share on other sites More sharing options...
noobieofdeath Posted December 16, 2020 Author Share Posted December 16, 2020 Well hell... CEL turned off while driving home... all’s well in legacyland. Thanks guys! Link to comment Share on other sites More sharing options...
wtdash Posted December 17, 2020 Share Posted December 17, 2020 If issue returns: My '96 Brighton had the speed sensor go bad. That tip spins and will eventually wear out. Easy enough to replace. Link to comment Share on other sites More sharing options...
