mrcheapyasui Posted November 23, 2020 Share Posted November 23, 2020 (edited) Hey I have a 94 legacy wagon with an NA ej22 and it suddenly stopped starting. The car was running fine before this and had no problems starting. Then this past week it would crank but never start. It has spark and fuel comes out of the fuel filter. I just checked the compression and all cylinders are consistently low, around 60-70 psi. The test was done with the cold engine. I tried putting oil in one cylinder and it went up from 65 to 85 psi. I have checked the timing marks and counted teeth repeatedly, and the timing looks good. I got a fuel pressure tester, but at this point it looks like the compression is the red flag. Let me know if you think I should test that still. Also the spark plugs smelled like gas, so it seems like there's gas in the cylinder. Is my engine just worn out? Any ideas of other things to check or things I could fix? Thanks! Edited November 23, 2020 by mrcheapyasui Link to comment Share on other sites More sharing options...
Brighton96 Posted November 23, 2020 Share Posted November 23, 2020 If the pressure raised with oil added to the cylinders then it's most likely failing rings. You can try soaking each cylinder with marvel mystery oil to see if it's because the rings are stuck/have dirt in them. Normally you'd check compression with the engine warm and at WOT but that's not always an option. You should have 90+ psi on a cold engine to start it. Link to comment Share on other sites More sharing options...
mrcheapyasui Posted November 23, 2020 Author Share Posted November 23, 2020 Thanks, I'll give that a try. Link to comment Share on other sites More sharing options...
