mkoch Posted November 20, 2020 Author Share Posted November 20, 2020 Managed to find an 05 LGT 5MT missing only the motor and exhaust. Wiring harness and even AC/power steering pumps still attached. Many thanks to you all for the insight on all of this. It sounds like I just avoided a huge financial mistake and can now pursue a slightly smaller financial mistake haha Link to comment Share on other sites More sharing options...
lagwagon Posted November 20, 2020 Share Posted November 20, 2020 Managed to find an 05 LGT 5MT missing only the motor and exhaust. Wiring harness and even AC/power steering pumps still attached. Many thanks to you all for the insight on all of this. It sounds like I just avoided a huge financial mistake and can now pursue a slightly smaller financial mistake haha Crank triggers patterns are different between 5EAT and MT cars so make sure you have the correct pulley for the ecu you are using (I assume since the wiring harness is intact, the original ecu is still inside the car). Link to comment Share on other sites More sharing options...
leetdrv Posted November 21, 2020 Share Posted November 21, 2020 Crank triggers patterns are different between 5EAT and MT cars so make sure you have the correct pulley for the ecu you are using please explain. All pulleys are identical between 5EAT and MT Link to comment Share on other sites More sharing options...
