96 legacy aftermarket keyless entry
Hi,
Probably a stupid question... So I have tried to build in a keyless entry system in my legacy BG II from 1996 but it doesn't work. The box lights up and clicks when I activate it with the remote. Following the manual found there: http://www.randomsoup.com/subie/subiealarmmanuals.html I plugged the box to the permanent + 12 V and the ground to the screw holding the door lock timer. Now in another I found, you connect the EOM keyless entry box to the wiring of the door lock timer. My aftermarket keyless entry box wiring looks like the one in the attached picture. As I understand from the door lock timer wiring, the car uses a positive and negative trigger. So I connected the according wires in parallel to the wires connected to poles 1 and 3 of the door lock system. When I did connect the wires to the permanent + 12 V and grounds it made a short. Should I also the +12V to pin 2 and GND to pin 4 of the door lock timer?
Any help would be very much appreciated.
Thanks a lot in advance!
Wiring diagram of the keyless entry box: instructions.jpg
Wiring diagram of the door lock timer: YTQBZ3xhttps://ibb.co/YTQBZ3x
