cdog Posted November 9, 2020 Share Posted November 9, 2020 When turning on the car but not cranking it the dash is different than it usually is. I currently have three check engine light codes but now the check engine light won't show up. The temperature for the oil is also staying at maximum temperature. Instead of showing the miles, the words "run mode changed system check" comes up. After trying to start it for a while I noticed that the purge valve coming out of the intake was leaking gasoline. I'm about to go check if any injectors are grounded. any additional input would be super helpful Link to comment Share on other sites More sharing options...
