fkyx Posted November 8, 2020 Share Posted November 8, 2020 Howdy! So yesterday I did the running belt on my wife's 2005 LGT, along with the water pump and an OEM thermostat. I used a Gate's running belt kit and an OEM thermostat and new gasket, both purchased separately. After I buttoned it all up and tried burping it, I noticed it wouldn't hit operating temp. So I figured the thermostat was bad, and today I swapped in the old thermostat with the new gasket from the Gate's kit, but I'm still not hitting operating temperature. It's worth noting that I dropped the new thermostat onto the ground, by accident, before I installed it. I had also taken the car for a short drive after installing that thermostat, and still didn't hit operating temp. I can't claim that I did everything correctly, obviously. Nothing is leaking outside of the car, though, haha. What do you think I may have done wrong or missed? Thanks, Matthew Link to comment Share on other sites More sharing options...
subisubisu Posted November 8, 2020 Share Posted November 8, 2020 You can often test a thermostat in a pot of water heated to near boiling, depending on your altitude (affects the boiling point of water) and the temperature at which the thermostat is set to open. Of course you need to stay aware that coolant is poisonous and not use the same pot you cook with if the thermostat has been in contact with coolant. I learned this because I had a similar problem on my Audi, but after extensive troubleshooting including changing out for the old water pump and thermostat like you did, my problem turned out to be that I had a sensor connected backwards. That doesn't sound like it could apply to your case. Link to comment Share on other sites More sharing options...
Scottydunno Posted November 12, 2020 Share Posted November 12, 2020 Just to ask because it's possible... is it installed the right way? Spring side towards the engine??? Scotty Link to comment Share on other sites More sharing options...
Infosecdad Posted November 12, 2020 Share Posted November 12, 2020 Direction of install of the thermostat (it can be installed backwards) or it's not fully burped. Sometimes it can take a while and effort to get it fully burped. Link to comment Share on other sites More sharing options...
