boxkita Posted September 17, 2020 Share Posted September 17, 2020 (edited) It took ~1500 posts to swap my hg. I'm hoping for something less to put 2 engines back together. Engine #1. FreeRangeRacing's RBP wagon's engine. had an oil leak. Engine #2. From birdmayne. unknown condition, was out of car. Edited September 17, 2020 by boxkita Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted September 17, 2020 Author Share Posted September 17, 2020 (edited) Parts to order. MrTris's rebuild thread - https://legacygt.com/forums/showpost.php?p=5269820&postcount=2 Gasket Set (06-07 lgt & specb) 10105AB010 261.35 Head Bolts (12) 11095AA042 100.92 Oil Cooler 21311AA051 214.61 Cam Plugs 11051AA070 (4) 8.52 PCV Curved hose 99071AC220 6.82 Power Steering Suction Hose 34611AG22A 23.76 Power Steering O-ring 34439FG000 1.48 Exhaust Cam sprocket 13049AA041 71.26 Exhaust Cam sprocket 13054AA033 71.26 Oil Control Valves (2) 10921AA020 176.80 Stock TMIC NEW 21821AA021 289.60 New Stock BPV 14471AA130 73.75 Oil Pump stock 10mm (2) 15010AA300 277.42 5x for each head: 15027AA132 1x for each head: 11051AA170 3x for each head: 11051AA081 xt2005bonbon's gasket thread - https://legacygt.com/forums/showthread.php/full-gasket-kit-content-10105aa720-203457.html master kit for 05-06 engines - 10105AA720 from VisciousSquirrel's thread - https://legacygt.com/forums/showpost.php?p=5987750&postcount=13 Here is the gasket set list that I used from 2phless on a certain other Subaru forum. "Gasket set part number 10105AA590 Gasket & Seal Kit - ENG My list key list number/part number/ part name/ quantity/ what it is or where it goes. 1 / 803928010 / GSKT-28.2x33.5x1 / 3 / silver seals for the 14mm allen block access bolts 2 / 806786040 / OIL SEAL-86x103x10 / 3 / Rear main seal. Why 3? I don't know. 3 / 10991AA000 / O RING-CYL BLOCK / 4 / 3 between block halves. 1 behind oil pump. ** Looks similar to pt # 11 ** 4 / 806931020 / O RING-31x2.0 / 1 (but came with 2) / #4 wrist pin access cover gasket (hidden by flywheel) 5 / 806932030 / O RING-32.6x2.7 / 1 / ??? 6 / 11034AA000 / WASH-CYL BLK SLNG 6 / for the 6 internal 12mm 12 point block connecting bolts that contact oil. 7 / 11044AA641 / GSKT-CYL HEAD / 2 / Head gasket pair. 8 / 803912040 / GSKT-12x16x1 / 14 / Copper bango bolt washers (except for the turbo oil feed) 9 / 806910170 / O RING-10x2 / 2 / 2 orange gaskets for the bottom of the dipstick tube. 10 / 806917070 / O RING-17.4x2.4 / 1 / oil fill tube to LH valve cover 11 / 11122AA000 / SEALING-OIL PAN / 1 / This goes between the oil pump pickup and block. ** Looks similar to pt # 3 ** 12 / 11126AA000 / GSKT-DRAIN PLUG / 1 / A crush ring for the drain plug. Nice of them huh? 13 / 805323040 / CIRCLIP-INR 23 / 8 / Wrist pin circlips 14 / 806742160 / OILSEAL-42x55x8 / 2 / Intake cam seals 15 / 806732160 / OILSEAL-32x55x8 / 2 / exhaust cam seals 16 / 13091AA050 / SEALING-TENSIONER / 2 / *** These are the rubber or foam stickies on the tensioner * 17 / 13091AA060 / SEALING-TENSIONER / 2 / * mount plate that keep dust out of the timing belt area ***** 18 / 806939040 / O RING-39.4x3.1 / 2 / AVCR intake cam oil covers (the triangular covers held to the front of each intake cam sprocket by 3 philips/8mm bolts) The next several part numbers are fairly unidentifiable. They are the foam stickies or rubber edges that seal the timing chain covers.They have no dimentions or valid descriptions. They either have obvious spots or don't. I've used RTV for the wishy washy areas before. 19 / 13581AA050 / SEALING-BELT CVR FR / 1 / 20 / 13594AA000 / SLNG-BELT COVER, 2FR / 1 / 21 / 13583AA260 / SEALING-BELT CVR RH / 1 / 22 / 13583AA270 / SEALING-BELT CVR / 1 / 23 / 13583AA280 / SEALING-BELT CVR / 1 / 24 / 13583AA290 / SEALING-BELT CVR RH / 2 / 25 / 13584AA050 / SLNG-BELT COVER, 2RH / 1 / 26 / 13597AA020 / SEALING-BELT CVR / 1 / 27 / 13597AA031 / SEALING-BELT CVR / 1 / See? 28 / 13592AA011 / MOUNT-BELT COVER / 7 / Snap in rubber coated metal spacers for the t-cover-to-block bolts. 29 / 13207AA050 / SEAL-INT VALVE / 8 / intake valve seals (green???) 30 / 13211AA050 / SEAL-EXH VALVE / 8 / exhaust valve seals (black???) I haven't checked the difference yet. 31 / 13210AA020 / COLLET-VALVE / 32 / Small metal wedges. Dip concave side in thick grease to stick to valves during install. 32 / 13270AA190 / GSKT-ROCKER COVERRH / 1 / Right valve cover gasket. 33 / 13272AA140 / GSKT-ROCKER COVERLH / 1 / Left valve cover gasket. 34 / 13293AA050 / GSKT-ROCKER CVR,2 / 4 / Spark plug hole gaskets 35 / 806733030 / OIL SEAL-33x49x8 / 1 / oil pump to crank seal (front main) 36 / 15048AA001 / SEALING-OIL PUMP / 2 / More rubber pads for timing chain dust control. 37 / 806922040 / O RING-22.1x3.5 / 1 / This may be the recirc valve kneck o-ring 38 / 803942010 / GSKT-42x51x8.5 / 1 / Oil fill-tube cap gasket. (This was a puzzler the first time I saw one) 39 / 21114AA051 / GSKT-WATER PUMP / 1 / Water pump gasket. (Coated Metal) 40 / 21116AA010 / SEALING-WATER PUMP / 1 / And another rubber dust gasket for timing chain area. 41 / 21236AA010 / GSKT-THERMO / 1 / Thermostat gasket. Inner rib snaps around radius of the thermostat. 42 / 21370KA001 / GSKT-OIL COOLER / 2 / Orange and 1 goes between oil cooler and block. #2 included for backup? 43 / 806959030 / O RING-59.6x2.4 / 1 / Blue??? Not sure where it goes. 44 / 806932040 / O RING-32.0x1.9 / 1 / Orange and goes between the two block halves. 45 / 14035AA421 / GSKT-INT MANIF / 2 / *** One of these is the intake to tumblers * 46 / 14075AA160 / GSKT-INT COOL / 2 / * and the other is Tumblers to heads ****** 47 / 16608AA040 / SEAL-FUEL INJ / 4 / Lumpy fuel injector seats 48 / 16698AA050 / O RING-INJECTOR / 4 / Lower small diameter injector o-rings ??? 49 / 16698AA060 / O RING-INJECTOR / 4 / Upper large diameter injector o-rings ??? (or reversed) 50 / 14038AA000 / GSKT-EXH MANIF / 2 / head to exhaust manifold metal gaskets. 51 / 14022AA160 / GSKT-MF / 2 / Exhaust crossover gaskets? PN may be a typo as 44022AA160 was listed but I don't believe it. 52 / 803910050 / GSKT-10x14x1 / copper turbo oil feed banjo gaskets 53 / 16175AA241 / GSKT-THROT CHMBR / 1 / Blue paper throttle body gasket. 54 / 806933010 / O RING-33.7x3.5 / Water jacket crossover pipe to right and left blocks. 55 / 21896AA072 / GSKT - INTER COOLER / 2 / *** one pair is for the Y-pipe to TMIC, the other * 56 / 21896AA010 / GSKT - INTER COOLER / 2 / * pair is TMIC to recirculating valve. (2 why?) ****" 57 / Aisin TKF-004 Cooling hoses. From this post: https://legacygt.com/forums/showpost.php?p=5987841&postcount=23 Engine Oil Cooler Line 807611031 Water Pump Upper Hose 807612011 Hose Clamp 805918010 Water Pump Lower Hose 807615182 Hose Clamp 805922090 Aux Res Coolant Hose 14472AA050 Aux Coolant Hose 14472AA040 Coolant Water Pipe Hose 807611090 Pre-Heater Hose 21204AA900 Pre-Heater Hose 21204AA830 Vacuum Hose 99071AC220 extra engine bay parts - 2015-2019 STi solid steering u-joint. #PN here: 34170VA030 Edited September 26, 2020 by boxkita Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted September 17, 2020 Author Share Posted September 17, 2020 reserved #2 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted September 17, 2020 Author Share Posted September 17, 2020 reserved #3 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
k00laid83 Posted September 17, 2020 Share Posted September 17, 2020 I just picked up these parts through Flatirons Tuning. By far the best prices for OEM parts. Just make sure you make a big order to avoid paying for shipping. https://www.flatironstuning.com/ 19 / 13581AA050 / SEALING-BELT CVR FR / 1 / 20 / 13594AA000 / SLNG-BELT COVER, 2FR / 1 / 21 / 13583AA260 / SEALING-BELT CVR RH / 1 / 22 / 13583AA270 / SEALING-BELT CVR / 1 / 23 / 13583AA280 / SEALING-BELT CVR / 1 / 24 / 13583AA290 / SEALING-BELT CVR RH / 2 / 25 / 13584AA050 / SLNG-BELT COVER, 2RH / 1 / 26 / 13597AA020 / SEALING-BELT CVR / 1 / 27 / 13597AA031 / SEALING-BELT CVR / 1 / Link to comment Share on other sites More sharing options...
boxkita Posted December 2, 2020 Author Share Posted December 2, 2020 (edited) Howto thats not in the fsm: Valve guide seals: use needle nose to pull them, vigorously or buy the correct tool from a tool truck (part number needed) new ones: On rock auto, the universal is for intake. The exhaust set is more temperature resistant, hence the different colors on oem. put all of them in a cup of oil & let soak use 9mm 12pt deep socket with extension & small ball peen hammer to set them. go until bottoms out Edited December 4, 2020 by boxkita Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Rusty9 Posted June 17, 2021 Share Posted June 17, 2021 Thanks for putting all these part numbers here! Link to comment Share on other sites More sharing options...
