meier motor sports Posted August 8, 2004 Share Posted August 8, 2004 i am gona want to install guages in my car. boost, a/f, oil press if not allready equiped. intake air temp maybe. [url]http://www.spa-uk.co.uk/design/dualtacho.htm[/url] i would use thoes dual guages. is there any a piller guage sets out there or amybe a pod for where that bucket thing is above the radio Edit (by axis008): Changed topic name to have correct spelling. Just a pet peeve :D Link to comment Share on other sites More sharing options...
Limeydriver Posted August 9, 2004 Share Posted August 9, 2004 There is a gauge kit available in Japan for the Legacy. looks a little pricey (about $980). It is supposed to be available in the US later this year. So I think you should be able to fabricate your own version much cheaper using the same setup as the Subaru version. Link to comment Share on other sites More sharing options...
Xenonk Posted August 9, 2004 Share Posted August 9, 2004 I am an HKS CAMP person FIRST ( [url]www.hksusa.com[/url] ) as well as [url]www.nordskog.com[/url] and [url]www.dakotadigtital.com[/url] check all of them out Keefe Keefe Link to comment Share on other sites More sharing options...
meier motor sports Posted August 9, 2004 Author Share Posted August 9, 2004 [url]www.nordskog.com[/url] isnt in englisg but looks to be a gun or shooting or scope site and [url]www.dakotadigtital.com[/url] isnt loading at all. but the first one lookes usefull Link to comment Share on other sites More sharing options...
agctr Posted August 9, 2004 Share Posted August 9, 2004 The JDM version does look at lot tidier and neat so for me I would hold out for that version but yes agree, its a little pricey. Link to comment Share on other sites More sharing options...
axis008 Posted August 9, 2004 Share Posted August 9, 2004 [url]www.dakotadigital.com[/url] ... Xenonk spelled it wrong (digtital). -ben Link to comment Share on other sites More sharing options...
InterCooled Posted August 10, 2004 Share Posted August 10, 2004 Those are nice digital gauges but you want these gauges. Best on the market. They will probably be a little expensive, but they are the most acccurate. Take a look. [url]http://www.defi-shop.com/[/url] Another good one is [url]http://www.autometer.com/[/url] take a look at the Cobalt series. Link to comment Share on other sites More sharing options...
fan42025 Posted August 13, 2004 Share Posted August 13, 2004 This is what I'm aiming for - [url]http://www.ecutek.com/products/incardash/[/url] Now all I have to do is figure out where to mount the 7" LCD display. Link to comment Share on other sites More sharing options...
meier motor sports Posted August 14, 2004 Author Share Posted August 14, 2004 [img]http://www.spa-uk.co.uk/design/pics/dual1b.jpg[/img] waht i like about these guages is the look of them. not some tacky add on guage or a lcd pannel or anything. and with 2 guages u can get read outs on 4 items. take a look into them [code:1:c997477c32]DG 200B Oil Pressure / Water Temperature DG 201B Oil Pressure / Oil Temperature DG 202B Fuel Pressure / Water Temperature DG 203B Water Temperature / Oil Temperature DG 204B Volts / Water Temperature DG 205B Brake Bias - Front / Rear DG 206B Turbo Boost / Temperature DG 207B Fuel Pressure / Volts DG 208B Oil Pressure / Volts DG 209B Oil Temperature / Oil Temperature DG 210B Temperature / Temperature DG 211B Boost / EGT Kit DG 212B Fuel Pressure / Oil Temperature DG 213B Pressure / Temperature DG 214B Transmission Temperature / Rear End Temperature DG 215B Fuel Pressure / Oil Pressure DG 216B Boost / Fuel Pressure DG 217B Boost / Oil Pressure [/code:1:c997477c32] Link to comment Share on other sites More sharing options...
brady_bunch Posted August 14, 2004 Share Posted August 14, 2004 [quote name='fan42025']This is what I'm aiming for - [url]http://www.ecutek.com/products/incardash/[/url] Now all I have to do is figure out where to mount the 7" LCD display.[/quote] Now that looks pretty slick. Keep us up to date if you go that route and let us know if you encounter any problems or issues. I wonder if you could fit a display in the dash cubby that would be big enough to display everything clearly? Is the display fully configurable or do you have to use a preconfigured display? Link to comment Share on other sites More sharing options...
fan42025 Posted August 14, 2004 Share Posted August 14, 2004 Don't enough about how configurable it is - I presume it's at least to the point of positioning and labelling the objects on the screeen, as well as defining your own skins. Once I've figured out what type of display and where to put it, I will definitely go ahead with it. I then want to add a bluetooth unit to it so I can synch with my phone and touch select the contact in the address book on the screen. Link to comment Share on other sites More sharing options...
InterCooled Posted August 14, 2004 Share Posted August 14, 2004 Those are pretty slick, but I am going for the needle gauges, not digital. Looks cool man. Go for it and keep us up to date on things.!!!! Link to comment Share on other sites More sharing options...
