2005 JDM b4 5 speed transmission problem need help
Krusez31
 Share
  • 4 months later...
Yeah, I'll guess broken shift fork.
Had the same problem back in late 1970's in a Chrysler 4-speed. Pulled the side cover, replaced the aluminum forks with brass ones I got from a buddy. Traded him a fiberglass seat for them.
Things were so much easier back then...
Engine Build - Click Here
I wouldn't know if the JDM forks are the same as USDM.
You might reach out to https://avoturboworld.com/
Or one of the larger Vendors here, may be Rally Sport Direct, etc. Or the guys at PPG
https://www.ppgearbox.com/product-page/suabru-1st-4th-drag-gear-set-v2
 Share
