M90 Supercharged Ej257
gtonstilts
Hey everyone I recently started posting a build series for my 05 Outback 2.5xt
it is fully built/Ballanced Internals, The B25 Heads are ported, with upgraded springs. The Boost is Delivered by an Eaton M90 Supercharger from a 3.8L Ford Supercoupe. It has Air to water inter cooling. I did a 5Mt Swap from the auto trans. Upgraded fuel system 850cc 65c parallel lines. Custom made 8 Rib crank/Alt pulleys. Turbo system deleted. Spec B Suspension, Summer tires, Weight reduction, It got a new satin black paint job, and so much more
check out the channel on YouTube "Boosted Problems" Watch, comment, & Subscribe. your support means a lot !
https://www.youtube.com/channel/UCKiBA3u__mVyWJNaHN1eSOA?view_as=subscriber
  • 3 weeks later...
That is quite the neat project
  • 1 year later...
  • 6 months later...
  • 2 months later...
I would suggest you make a post in the 4th Gen Forum with a link to this, very cool project. Or in the Powertrain forum.
Engine Build - Click Here
