njimen1 Posted July 20, 2020 Share Posted July 20, 2020 I have a Subaru Legacy 2008 2.5. I have a bad leak on it and I replaced the oil pressure switch. Thinking that would result the problem but once I turn the car on, it started smoking from under the engine. Where the exhaust attaches to the engine. White thick smoke came out. It has a burning smell. Not sure what it is. Any thoughts? Link to comment Share on other sites More sharing options...
Chocoholic005 Posted July 20, 2020 Share Posted July 20, 2020 I'm afraid we're going to need a lot more information to diagnose. Why did you think replacing the oil pressure switch would fix an oil leak? Was the oil pressure switch leaking? Smoke from the exhaust probably means oil is dripping on the exhaust, but which side is smoking? Additionally, typically the pictures section is for pictures. You'll get better exposure in the proper section. Link to comment Share on other sites More sharing options...
njimen1 Posted July 20, 2020 Author Share Posted July 20, 2020 Thanks for replying. After inspecting the oil spill all over the engine, I pinned down the oil leak to the oil pressure sensor because it wasn’t screwed all the way in. It was half way in. I clean the area and replaced the sensor. The smoke came out seconds after I turn the on. I’ve seen when smoke its cause by the oil spill on the parts of the engine that get hot. But this was different. It looked like the smoke was coming out of the area where the exhaust meets the engine (I clearly don’t know wth I’m talking about because I don’t what the part it’s called) lol. It was a white smoke and it smell like burnt. I’ve attached a picture of the area where the smoke was coming out. The car hasn’t been run for over a month. Link to comment Share on other sites More sharing options...
njimen1 Posted July 20, 2020 Author Share Posted July 20, 2020 http://file///Users/nestorjimenez/Documents/IMG_4826.pdf Link to comment Share on other sites More sharing options...
Chocoholic005 Posted July 20, 2020 Share Posted July 20, 2020 Unfortunately your pictures haven't come through; I understanding what you're saying, but a picture will help immensely. Was it driver or passsenger side exhaust manifold? Link to comment Share on other sites More sharing options...
njimen1 Posted July 20, 2020 Author Share Posted July 20, 2020 For some reason the pictures aren’t uploading. The smoke is coming from the drivers side. I’ll try with my computer once I get home. Link to comment Share on other sites More sharing options...
