ekwilson08 Posted July 15, 2020 Share Posted July 15, 2020 So I built my motor about 8k ago, using sti crankshaft, eagle rods, manley pistons. and king bearings. new subaru oil pump Engine is running strong and clean no issues there. I just installed an oil pressure gauge and i have a few questions. so today its 85 degrees out when i let for work this morning and on engine start my gauge is at 90 psi. by the time i get to work about 10 minutes at idle im around 17 ish. but lets say i go and do some highway driving for extended period of time or go and do a few pulls or just driving back roads is where i think i may have a problem, after those scenarios my oil pressure at idle is like 10-12 psi. If i bump the rpm to like 1k i shoot up to like high 20s almost 30. is this normal? or do i have a issue? the oil im running right now is lucas oil 5w-40. Link to comment Share on other sites More sharing options...
awfulwaffle Posted July 15, 2020 Share Posted July 15, 2020 Startup pressure checks out to me. My car idles hot at 750 RPM @ 25 psi on 5W40, but it's an OEM block. Where'd you set clearances at? Oil pressure look good on power? Link to comment Share on other sites More sharing options...
ekwilson08 Posted July 15, 2020 Author Share Posted July 15, 2020 Startup pressure checks out to me. My car idles hot at 750 RPM @ 25 psi on 5W40, but it's an OEM block. Where'd you set clearances at? Oil pressure look good on power? oil pressure is good on power and driving, its only at very hot idle where i have an issue. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 16, 2020 Share Posted July 16, 2020 How does that oil stack up in the ratings ? Is it known to break down sooner then other oils ? We know Mobil 1 5w-30 breaks down to a 5w-20 fairly quickly. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ekwilson08 Posted July 17, 2020 Author Share Posted July 17, 2020 How does that oil stack up in the ratings ? Is it known to break down sooner then other oils ? We know Mobil 1 5w-30 breaks down to a 5w-20 fairly quickly. Ok where would I find this information? Link to comment Share on other sites More sharing options...
Notorious Posted July 17, 2020 Share Posted July 17, 2020 What gauge are you using? Mechanical or electric? And where was it tapped and where was it grounded? A bad ground on an electrical gauge can cause readings to be off. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 20, 2020 Share Posted July 20, 2020 Ask google or Bobistheoilguy 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ekwilson08 Posted September 28, 2020 Author Share Posted September 28, 2020 Just changed my oil with liqui moly 5w-40 and oil pressure is way better at all temps. Maybe the lucas was a lower viscosity then rated not sure Sent from my SM-G975U using Tapatalk Link to comment Share on other sites More sharing options...
