revilo Posted July 14, 2020 Share Posted July 14, 2020 hi all, as the title mentions in searching for front axles for my 04 JDM GTB with a 5mt. The parts fiche specifies • 28321AG020. I wonder if a compatible axle was used on USDM Legacies or another USDM suby so I can request one from my local dealer. If be grateful if someone could help me out. I also need brake pads, are they the same as the USDM lgt's? Thanks in advance. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 20, 2020 Share Posted July 20, 2020 I wonder if you might source an axle from a junkyard. That way if its not useable its easy to return it. Ask them first. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
