awfulwaffle Posted August 16, 2020 Share Posted August 16, 2020 (edited) I'd go 25 out of the choices listed. Most sources seem to indicate there's no significant increase in rolling resistance between 23 and 25, but 25s will be a tad more comfortable. 28 if the rims are too wide for 25s. EDIT: That said, I ride 32c Schwalbe Marathons on my commuter and they're just fine from a rolling resistance standpoint. On long hauls I prefer a little more give. Good looking bike, congrats! Edited August 16, 2020 by awfulwaffle added qualifier Link to comment Share on other sites More sharing options...
ehsnils Posted August 16, 2020 Share Posted August 16, 2020 From Stack Exchange: Some of the confusion relates to the fact that there are different but equivalent ways to measure tire sizes. The first tire measurement you mentioned 44 622 refers to the tire width of 44 mm and rim bead seat diameter of 622 mm respectively. The second measurement type (700x45c) is a 45 mm wide tire that also fits on a rim with a 622 mm bead seat diameter, the 700c is an old French sizing nomenclature based on the final external diameter being 700 mm for width class of tire (e.g., a, b, c widths). (The final outside diameter is affected by the widths, so the three widths would have different bead seat diameters in order to get a final diameter of 700 mm).https://bicycles.stackexchange.com/questions/57437/44-622-700x45c-what-tyres-to-buy So it seems to be a pretty standard tire size, but more common is the x-622 marking, so you might want a 32-622 or 37-622. The 622 is the diameter of the rim, the 32 or 37 is how "fat" the tire is, both are millimeters. Or a 23-622, but too small tire can be a pain in the butt too. Link to comment Share on other sites More sharing options...
Tehnation Posted August 16, 2020 Author Share Posted August 16, 2020 shouldn't a 700c rim fit any 700c tire? Link to comment Share on other sites More sharing options...
Tehnation Posted August 16, 2020 Author Share Posted August 16, 2020 why is this so confusing lol Link to comment Share on other sites More sharing options...
awfulwaffle Posted August 16, 2020 Share Posted August 16, 2020 700c is the 'diameter' of the wheel, though as ehsnils pointed out they're actually 622 mm diameter. However, rims will come in different widths as will car wheels. Generally, you don't 'stretch' a bike tire like you would on a car, so you want your rim to be the same width or narrower than your tire. There's a limit to how much narrower the rim can be than the tire. Link to comment Share on other sites More sharing options...
ehsnils Posted August 16, 2020 Share Posted August 16, 2020 shouldn't a 700c rim fit any 700c tire? It could be that the rim is a bit too wide on the bead, so it could be a problem, you need to check the width so it's not wider than the tire or you'd get some issues with the tire creeping off when taking tight turns at speed or headaches with the tube wanting to come out between rim and tire when you try to get it together. Link to comment Share on other sites More sharing options...
awfulwaffle Posted August 16, 2020 Share Posted August 16, 2020 I'll ask a follow up question. Have you tried riding the tires that came on the bike? The tread looks pretty smooth to me. I bet if you inflated them to their max rating so they're nice and stiff they'd ride pretty good without too much rolling resistance. Link to comment Share on other sites More sharing options...
Tehnation Posted August 16, 2020 Author Share Posted August 16, 2020 Its raining outside so I couldn't take it out. I guess I'll try it first. Link to comment Share on other sites More sharing options...
Tehnation Posted August 16, 2020 Author Share Posted August 16, 2020 (edited) I'm just not a fan of these big ass heavy tires lol Bike weighs 32 lbs, i'm wondering if I can shave a lb or 1/2lb from these tires. Edited August 16, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Tehnation Posted August 16, 2020 Author Share Posted August 16, 2020 My rim diameter is 25" . Is that the normal size? Link to comment Share on other sites More sharing options...
laz Posted August 16, 2020 Share Posted August 16, 2020 Between 28-32 should be good. --- Link to comment Share on other sites More sharing options...
Tehnation Posted August 16, 2020 Author Share Posted August 16, 2020 Just went for a stroll, tires aren't bad at all. For now its fine, sooooo Let's talk about tech! I need something to log heart rate from my watch, track my mileage, cadence, gps etc. Any leads on a well priced product and an app? Link to comment Share on other sites More sharing options...
laz Posted August 17, 2020 Share Posted August 17, 2020 (edited) Just went for a stroll, tires aren't bad at all. For now its fine, sooooo Let's talk about tech! I need something to log heart rate from my watch, track my mileage, cadence, gps etc. Any leads on a well priced product and an app? Strava.com The official app for cyclists. But you also need sensors for cadence. Speed you can get away with the built in GPS. Honestl yhe watches are not that accurate. I do a HR strap feom Wahoo and have a Wahoo Bolt computer with all the sensors. Edited August 17, 2020 by laz --- Link to comment Share on other sites More sharing options...
awfulwaffle Posted August 17, 2020 Share Posted August 17, 2020 I'm just not a fan of these big ass heavy tires lol Bike weighs 32 lbs, i'm wondering if I can shave a lb or 1/2lb from these tires. My take on this is and always has been - it's better/cheaper to take a pound off of me than it is to take a pound off the bike. Only at peak cycling condition back in college have I ever been able to justify spending money on lighter parts. Then I got a desk job, started lifting seriously and grew a powergut, and the hundreds of bucks I spent to cut a few lbs off my roadie are meaningless Link to comment Share on other sites More sharing options...
Tehnation Posted August 17, 2020 Author Share Posted August 17, 2020 I just don't like 2 inch tires! Link to comment Share on other sites More sharing options...
theomessi Posted October 23, 2023 Share Posted October 23, 2023 I totally get your perspective on the weight vs. spending issue. Link to comment Share on other sites More sharing options...
Kalgonchik Posted October 23, 2023 Share Posted October 23, 2023 (edited) Staying in good cycling shape can definitely make a bigger difference than shelling out on lighter parts, especially when life takes you in different directions like a desk job and serious lifting. Priorities shift, right? By the way, have you ever considered checking out cycling insurance? It's a great way to ensure your investment stays protected, regardless of how the pounds are distributed – whether on you or the bike! Edited October 26, 2023 by Kalgonchik Link to comment Share on other sites More sharing options...
