2020 TouringXT Air Conditioner
The most common causes of broken air conditioning are leaks or compressor issues. If your air is blowing cool but not cold, the problem could be a clogged filter, cooling fan problem, radiator trouble, or it could simply be that you need to recharge your AC.
Not to be disrespectful, but are you sure it is on...there were times when I thought mine was and then went into the settings and it wasn’t. I needed to touch the AC rectangle on the screen. Also, remember that you can assign one of those touch buttons to the main screen.
 Share
