Battery replacement - suggested models
It's getting to that time where most Gen 6's will need a new battery.
I've read through the forums, and no clear consensus exists beyond the factory battery is terrible and underpowered.
What is everyone installing?
Options:
OEM - Group 25
Upgraded - Group 25 AGM battery
Higher CCA - Group 34 battery
Higher CCA - Group 34 AGM battery
Something else?????
What are your suggestions and experiences?
I wonder if the higher CCA really produces a faster crank speed when starting. The current CCA (I think 300) oem batteries seem woefully slow to crank in the cold temps.
Battery just went out on me couple of weeks ago. I just went to o'rileys and got the best one they had on shelf. a little more powerful than the stock and fit like a glove.
Group Size (BCI): 25
Cold Cranking Amps (CCA): 550 CCA
Cranking Amps (CA): 690 CA
Voltage (V): 12 Volt
Length (in): 9-11/16 Inch
Width (in): 6-7/8 Inch
Height (in): 8-13/16 Inch
Weight (Lbs): 35.5 Lbs.
Link
 Share
